Recommended Tempered Glass screen protector?
I just got a cheap UniqueMe glass protector. Nothing special, but It works and so does the fringerprint. Wanna know why? I put lotion on my finger when i registered them and they work about 95% of the time.
I know we talked about this when the phone first came out, and we were all trying to figure out which brand works with the fingerprint. But you don't need some expensive dome or liquid glue.
Just some lotion when registering your finger. Now if you have really dry hands thats gonna be a problem because you might have to apply lotion often.
P.S. I havent even turned up screen sensitivity with the glass screen protector on. I did try on, but it was a marginal improvement for me.
Even without a screen protector, if my fingers are too dry I have to moisten my skin for it to work.
UPdate: after a day of usage the fingerprint scanner still worked well, until i took a shower. I came out of the shower and the FPS wouldnt work it worked maybe 5% of the time. I was up for about an hour of so and it was not working at all after the shower. Fast forward to this morning and its working fine again, works even with a light tap. Each finger is only registered once, each print is registered in a circle motion. Thats it, I hope other people can also achieve these results without buying expensive protectors.
Perhaps you can register one after you get out of the shower so it is recognizable next time?
I dont think that would work. Maybe my fingers were too wrinkled after the shower.
Yeah pruned fingers won't match. I wonder if they prune the same way every time, so if you register a pruned finger. I feel like I have to try it. For science.
Bmws5
