[RECOVERY] CWMT Recovery 5.0.2.7-th7 (T is for TOUCH!) OV
Should we have official CWMT Recovery suppport?
  • Total voters
But there is one thing that i found
i had CM9, CM7, and Gapps, but the recovery only reckonized CM7 not even the Gapps
Thats strange. I have had no problems with any gapp zip. Can anyone else confirm this issue?
Plus Im thinking of creating a poll later. I figured if there isnt enough people here that wants a touch recovery theres no sence drew wasting his time supporting the OV.
The touch recovery is awesome it makes things way easier :)
Maybe im the only one with the problem...
I added a poll to see if we should get Official CWRT support. The poll is public. This will show either we really want this recovery or we dont so drewwalton19216801 isnt wasting his time on an ov version. This poll does not mean we will get official support if there are alot of yes votes. I did this to show that we want or dont want support in hopes of our own OV CWRT. If drew feels this poll needs to be taken down I will do so.
Wow I especially like the wipe system, cache, and data all at once option. Is there a recovery that flashes boot, system, cache, data, and sd-ext?
I've been thinking about this lately too. It's all based on scripts, right? So it should be easy to write one that does all that. I'll look into it later.
works, though just like non-touch, i can't install flashable zips that aren't roms (beats, titanium backup)
i thought there was an issue with titanium backup zips and had problems with any recovery. and for the beats audio zip i have no clue. never liked the beats audio when i had my MT4G.
If you can post the link to the beats audio I'll try to flash it.
Sent from my Quattrimus ICS OV.
So do u think i should flash the recovery a different method and see if that fixes the problem?
it wouldn't hurt to try. Maybe the gapp zip is bad just a though
I can't load teamhydro's website. Is anybody having the same problem?
Edit....I tried from my PC and phone downloaded to both with no problems.
Are you trying from your phone?
I tried a different way of flashing the recovery and still only CM7 appears not even CM9 or the gapps :(
I have no clue. I flashed Harmonia 2 last night with gapps(though not needed) then flashed back to quattrimus this morning no problems. Let me wipe my phone and flash cm7 with gapps and flash cm9 with gapps and see if I get that problem.
Could you be flashing the wrong gapp zip with the wrong rom? Just a thought.
doxidex23
