RedMi Note 3 Pro & Gear Fit2 connection
gmillas
3
I own the following devices.
Xiaomi RedMi Note 3 Pro
android 5.1.1LMY47V
MIUI 7.5.1.1
Gear Fit2 SM-R360
software R360XXU1BPG3eChO
I installed the
Gear 2.2.16101261
Gear Fit2 Plugin 2.2.04.16111741N
Samsung accessory service 3.1.26_161116
I perform the pairing proccess from gear app where it normally sees the request and then the gear (app from mobile) is closed without any message and gear fit2 stays on screen writing "setting up" where nothing else happening and at the end sent message that "the setting has lasted more than expected. Do you want to try again; "
For the above issue I have tried the following:
1)
Remove all Samsung app's
cache cleaning
Factory reset gear fit2
Reinstalling app's
2)
cache cleaning
Reinstalling previous versions
Please HELP
I can not really think anything else but to try factory reset phone itself...I am using GF2 with my MiMax on Miui 8.0.1.3 without any issues
Chris34728
