Renaming RUU questions
Skatergirl... Do the same thing for me please.... Boot into the phone all the way... Using the usb cable connect it to you phone... Set it for disk drive and not charge... The if you double click on the last drive letter and it opens in windows explorer.... Is your phone file there
From my XxX rated Rezound
Now my phone does not want to boot up at all!
As soon as it starts to behave, I will do that check for you!
Well we have not done anything to it yet.... I think it is just pissed it isn't on ics yet.... Lol
Your screenshot shows no ph98img.zip file loaded on the ext_sd. Or your file has a .zip.zip extension but either way your phone is not seeing the file.
Sent from my ADR6425LVW using Tapatalk 2
Yeah, it goes through the whole drawn out cycle and then when it gets to the password, it goes back to black screen and it reboots. Maybe I should go back to HBOOT and do a factory reset and start all over, cause the phone is stuck in an non cooperating cycle.
If you go to fastboot it should start
Fastboot is for running the executable file from your computer while the phone is connect via USB. You can do it that way but you cannot mix them.
K ... think I am just getting a bit tired! LOL!
I do see the sd card on my desktop through the cable. I am placing the zip file back on it.
Also make sure you have it named PH98IMG.zip . If you don't have extensions turned on in windows it might be named PH98IMG.zip.zip (notice the extra .zip)
I deleted the dang file and I am downloading it again. Maybe it did not download properly the first time.
I found my SD card. My pictures are still there, but my music is gone.
I don't regret trying this, but I am getting a little tired and a little weary. Not sure why most everyone else had no problems and I am stuck. :'(
In Windows if you do not have show file extensions on, it will show xxx. Zip when it really is named xxxx. Zip. Zip
Skatergirl, sorry for sorta bailing on you for the last hour. I am at my second job and people just aren't getting that it is more important to help you get ics than to make them a damn pizza
Reactions: skatergirl
richardschofield
