[Retired][ROM]Superclean 2.9.2 EA15/EB01/EB16/EC10 Based
I have tried all three and no go. I have even tried different GPS apps and none of them can even see any satellites.
All this tested while walking around outdoors no trees around or anything..when i connect to the wifi here indoors though its instant.
Well I ODIN'd to EC01 and still no GPS...im bangin my head against the wall here...the whole reason I upgraded to 2.9.2 was to try to get my GPS working again. I was on 2.6 and it worked for the longest time until 3 days ago...hasnt worked since.
try flashing EC01 through odin twice for good measure it wont hurt but it may help
Anyone having issues with Bluetooth after flashing 2.9.2v? I can't send pics to my mac... but can recieve pics from the mac. Thoughts?
Edit: Got it! For your MacBook to receive files via Bluetooth, you have to enable Bluetooth Sharing in the Sharing system preferences pane.
I just updated the radio to ec01 on sc too. GPS works great. I was having bluetooth connectivity problems with my car.. hopefully this will resolve that. I just noticed that where it reported SC2.9.2 before, it now just says SC2.9.
I flashed froyo today using DroidXcon step by step, if I wanted to add any Patches:
Clock package (includes infoalarm)
tw_clock_package.zip
Touchwiz video player (eb16)
tw_videoplayer.zip
DRM Package (eb01)
drm_package.zip
Samsung MMS (stock, eb01)
eb01_mms.zip
Touchwiz Launcher and widgets (eb01)
eb01_touchwiz.zip
TW Live walls (eb01)
eb01_tw_lwp.zip
TW Music Player (eb01)
eb01_twmusic.zip
2.2.1 Launcher, modded for SF
Launcher2.zip
Nuance (eb01)
nuance_froyo.zip
Thinkfree Office (eb16)
thinkfreeof these patches
Where could I find instruction on how to install any of them?
tw_videoplayer.zip
DRM Package (eb01)
drm_package.zip
eb01_mms.zip
eb01_touchwiz.zip
eb01_tw_lwp.zip
eb01_twmusic.zip
Launcher2.zip
Nuance (eb01)
nuance_froyo.zip
Those are just .zip files you flash in CWM. DroidXcon and I both include step by step instructions on how to flash them in our stickies.
SheepDog Elite,
I went back and read both and I didn't see the directions on how to do the flash in CWM. Sorry, wanted to get the clock package, TW Music Player and the TouchWiz Launcher and widgets. Sorry but like I said I couldn't find the instructions.
Thanks!
SheepDog Elite,
Thanks!
In the first time rooting walk through find the section on flashing the rom and kernel, these files will flash the exact same way.
1. Scroll down to "install zip from sdcard" and hit the power button.
2. Scroll down to "choose zip from sdcard" and hit the power button.
3. Scroll down to your "roms" folder, and hit the power button.
4. Select the "Insert_file_name_here.zip " file, and hit the power button.
5. Scroll down to "yes" and hit the power button.
For some reason, my touch screen is unresponsive or semi-responsive when the phone is plugged in and charging. Anyone else have this issue?
The same thing happened to me when I used a cheap ebay charger. It works fine with an OEM charger for me at least.
Is there a theme for 2.9.2 to make my dropdown menu look like original two dropdown?
Sent from my SCH-I500 using Tapatalk
Go to Jaekar99's themes thread, click on the developer name after each theme and look at the screenshots. You should see what the dropdown menu will look like. If none of them look like what you want, then no
Jaekar99's Themes Thread
Well im getting a new phone for free tomorrow...after restoring my phone back to stock my gps still didnt work :)
Wow this thread is huge now. Sorry if this has come up but I am having a hard time finding what I am looking for. About three weeks ago I got the Fascinate and rooted it using Adrenalynes helpful thread. My kernal is 2.6.32.9. Phone has been running well so I am unsure if I should go to 2.9.2. Only problem I have noticed is about every three days when coming out of a program I have no icons on my screen. Eventually they will come back but I have been doing a battery pull every three days to set it back to normal. When I say no icons I mean I can see the bottom tool bar, but nothing but my wallpaper above it. Is this a known issue? And will 2.9.2 fix that? It is almost like the phone is wicked lagging to go backto the home screen out of a program. Happens with many programs not a specific one. Thanks for your time.
I have started to have a very similar problem lately...BUT... It started
AFTER I went to 2.9.2 ... lol
It just happens every once in a while... I'll close out of an app and "poof"
back to an app-less home screen .... It just lags.. I can push home and it
snaps back to normal.... It's not a big deal to me now though... New stuff will be coming out soon..... :D
Yeah I am not incredibly bothered by it. I love the phone and they all have quirks. I guess being new to the whole rooting thing I am wondering if there are more stable but less customizable roms out there. I would love to become knowledgable but being honest with myself I don't have time to do more than dabble. I wanted the bloatware gone and 2.2 for the Flash and moving apps to the sd card. Unless something grabs my attention i probobly won't go any deeper.
Since going to SC2.9.2v I have noticed a notification ringtone that I cannot figure out where to disable or change.
I am using NoLed and K-9 email. It only happens when the phone is not on Vibrate or Silent. I have checked all of the NoLed, K-9 mail, ADW Launcher, and general Sound and Notifications that I can find.
The ringtone plays when there is a notification and will continue to play until the notification screen is opened.
Not a huge problem, just wanting to be able to pick a new notification sound or shut off.
I looked around on the forum and did a search. Couldn't find anything that seemed to mention this specific issue or suggest a fix.
btw, still loving SC2.9.2v and the Glowing Blue dialer from gunnermike's theme. Maybe this weekend I'll get around to playing with more than just the dialer.
Glad to see that ED01 is out, got friends that don't want to root...
Thanks,
Ok, so I flashed CWM all. I want to put the old music player, the clock package and the TW Launcher. Since I have flashed CWM, could I download those three files from Adrynalyne's thread right from my phone. Press the power button until it gives me the different options, and press recovery from there?
birdsong2000
