[Retired][ROM]Superclean 2.9.2 EA15/EB01/EB16/EC10 Based
Radio problems with SC 2.8
Love SC 2.8, but I'm having a weird problem with the radio that I haven't had prior. It seems that my radio is crashing or something, because after the phone has been up for 12 hours or so, I start getting connection errors with browser, facebook, etc. Then shortly after that it won't send or receive text messages either. A reboot makes everything good again.
I'm on the EB01 radio. Any suggestions?
Check this thread here. Adrynalyne updated with Q / A you may want to review. There is also a link to modems for SuperClean as somebody else was having an issue.
Review that thread. The links to modems with instructions are in it
Thread
If link don't work for you go to the Stickie thread:
Sticky: [ROM]Superclean 2.8 EA15/EB01/EB16 Based
Thread
good advice. i would start by reflashing eb01 radio. if no workie, dl30, then finally dl09.
Xcon, I was reading through earlier and I flashed the DL09 modem because it was considered 'better'. I did it through ODIN. Still shows EB01 in my settings. Did it not flash?
you are looking for base band version. the build will still show eb01.
Motivation for changing to the DL09 modem would be to improve battery life (YMMV of course), as the FAQ says, but would making that switch give up some extra functionality that the EB01 modem has?* Or is it going to be mostly indistinguishable? (Side note: The key interest I have is the dummy tether module, but that seems to be dealt with by the EB16 kernel (i.e., the main kernel, not the modem sub-kernel...don't think there is a EB16 modem kernel being used anywhere for Fascinate)).
Let me know if I have it straight, and thanks again guys!
*Please pardon if this is spelled out somewhere...did not see it here or in Sheepdog's post.
I guess I was just curious what switching back to the DL09 modem would do, and how it would do it, without getting too technical. I saw the OP, but it didn't really elaborate on the subject, so I figured I would see what the general consensus was..
print to logcat
fire off a toast
Thats basically the whole app, no malware in it. Contains no other code, and no separate binaries. (Shortest malware analysis EVER!!) I say ditch AVG.
Thats more or less the whole app.
GPS issues with Superclean 2.8?
Hi, so I just got my replacement phone after having some issues with my other Fascinate, and I flashed this ROM without installing any of the other updates like the previous GPS fix update. I dont know if that has anything to do with my issues, but I cannot get my GPS to lock! It's just as bad as when I didn't have the GPS fix update!! I love having froyo, but not having GPS work is painful!!! Anyone have any insights??
Hello Adrynalyne,
Can you please add a patch for the Samsung Dual Clock widget? I believe it is the dualclock.apk file.
Thanks in advance.
stoffe949
