[Retired][ROM]Superclean 2.9.2 EA15/EB01/EB16/EC10 Based
"Possible" means the kernel may possibly allow you to tether your phone without Verizon being able to monitor it to charge you for the data usage.
Ok , so no need to reflash eb16 kernel after flashing 2.8.
Sent from my SCH-I500 using Tapatalk
No real need to since it is included in the ROM. If for some reason you find you are not getting whatever features you are supposed to get from the EB16 kernel, you can always flash it then. It won't hurt anything to flash the kernel. Just realize that the EB16 kernel breaks bluetooth. So if you use bluetooth, you will need to flash the EB01 kernel. If you also use the tethering feature, that is only available with the EB16 kernel, not the EB01 kernel. So if you use bluetooth and tethering, you will need to make a choice which one you want more and use the appropriate kernel. For now we don't have a kernel that gives you both.
i'm on 2.8 just havnt updated in my profile. yes i have EB01. will DL09 give me better battery life. thats the only reason for the change because i saw it in Adrynalyne tips ?
I flashed EB01 Superclean 2.8 with Super Dark Theme. Not sure which did it, but better life is 10x better than when I had DL09. With DL09, the minute I turned my phone on after a full charge, it would be 95%. I would have no other choice but to plug it in at least once a day, and this is even after barely using it throughout the day.
But after having EB01/Superclean 2.8/Super Dark for the past 2 days, I've had excellent battery life. Same amount of apps as before, not doing anything different. Battery is currently 35%, and this is after it has been on for about 14-1/2 hours.
Thank you to everyone who has make these ROMS/Kernels/Themes. I love the super dark theme and the way my phone is running.
Fascinate super clean
land shark, the other night "stand up dad" walked me into the EBSC26_DXC.tar-
is it posible to get the SC 2.8. i tried last night and the Odin Program had it almost completed and then poof, Odin went dead in the water..i watched the small blue line slide across the face all the way from left to right..but then i had the triangle between cpu and ph.. any ideas of what went wrong ..i did get back into EBSC26_DXC.TAR.MD5 smooth as a whistle ..although it took awhile for Odin to finish up. about 5 minutes total not counting the wasted minutes trying to load EBSC28_DXC.TAR
you say the word and i'll give it another try.
Have you flashed anything through clockworkmod recovery yet?
I used that over the weekend and it worked for me without issue.
I would give it another try. Should work without issue.
Either way please move the convo to my thread or a new one as not to clog adrynalynes please
Well it's your call. You can try the ODIN method one more time, or I can walk you through flashing the ROM in cwm.
I loaded SC 2.8 yesterday. Didn't have any issue until I charged the phone overnight. Now I have the sleep of death. It was fine all day yesterday and today SoD. If I leave it plugged in it does not do it. I have wiped the dalvik cache and the cache partition. How do I get it to stop?
From the first post in this thread:
Q: My phone goes to sleep, only to never wake up!
A: I'd love to take credit for this, but cannot. This seems to be a common Froyo bug. I have been unable to track it down, but it seems to happen MUCH less frequently to those who do NOT restore with Titanium backup. So I've little doubt its a rogue app(s) out there.
Did you restore any apps with Titanium Backup?
No I did not use titanium backup to restore anything. It was fine until this morning. The stock rom does not do this. I really want to use SC because the phone runs way better. Is there anything I can try?
I would start looking at the apps you have installed. Are the apps from the market where you can easily get them back?
You may want to consider wiping the phone and going to a fresh SC2.8 install with no apps and then start getting them installed again via the market.
I would only install the essential apps you need and see if you have an issue then add more and see if / when the problem comes back.
Somebody else may have a better idea but from what Adrynalyne posted that is where I would start.
Strange, I have downloaded 2.8, and on the previous roms flashed the eb16 kernel after installing the rom and have never had a problem with bluetooth through my ford sync. Has it been confirmed that bluetooth is not working with eb16?
I am not sure as now I have it working with EB16 now too. Here is my breakdown.
formatted the phone clean
installed SC2.8 non voodoo
installed my apps
Installed SC2.8 voodoo
CWM did a nandroid backup
forgot to setup my bluetooth
Next
I installed Steel Blue theme for 2.8
realized bluetooth was not setup could not get it to work
I flashed the EB01 Kernel now bluetooth works
Next
Noticed my market was not functioning it would FC
CWM cleared Davlik same problem
CWM cleared data / cache
Then the phone would boot but when I unlocked I would get many functions of the phone FC. Had to three button recover
Next
I flashed SC2.8 Voodoo again. This flash has the ROM / Kernel EB16
Restored Nandroid backup created above
Phone works fine no issues and Bluetooth is working also
Now I figured everything is working so I went to flash the Steel Blue 2.8 theme again. the phone would not boot and was in a FC loop at bootup animation!
Went back to CWM and restored my Nandroid back again. Everything is working except I don't have Steel Blue installed which I love :(
Flash a theme.. this is what worked for me. I'm using Superdark.
so 2.8 comes with the kernal? I just need to flash sc 2.8 with cwm and then I can install any addons through cwm that I need like think free office? Am I correct in all this?
I have no problems using bluetooth with Ford Sync or Kenwood. I have SC2.8 voodoo on my phone and SC2.8 non-voodoo on my wife's phone.
sarahbond585
