[Retired][ROM]Superclean 2.9.2 EA15/EB01/EB16/EC10 Based
Hey guys! Just flashed the rom after getting a replacement phone without updating the stock phone to any of the other updates like DL09(this is the GPS fix update right??) So now i can't get my phone to GPS lock, its just as bad as before the GPS fix update... Anyone have the same problem or have insights??
Do you have verizon and google assisted location services checked off?
Hi, so I just got my replacement phone after having some issues with my other Fascinate, and I flashed this ROM without installing any of the other updates like the previous GPS fix update. I dont know if that has anything to do with my issues, but I cannot get my GPS to lock! It's just as bad as when I didn't have the GPS fix update!! I love having froyo, but not having GPS work is painful!!! Anyone have any insights??
check out post one of superclean thread. also i have had luck by switching which app im using. if i could not get google nav to lock i switch to google maps and it locks right away. its wierd.
Please read the FAQ on the first post.
Thanks.
So is this just an issue with Superclean 2.8? Because before receiving my replacement phone, I had flashed Superclean 2.6 and GPS worked just fine (which is why I thought my issues now might have something to do with my not having installed the GPS fix update before flashing 2.8).
Its an issue with any Froyo rom. The only gps stuff removed from superclean is verizon agps. That is totally worthless.
What about the original calculator patch or .apk or whatever form you have it in? I like it so much better than the new one. Thanks in advance.
is there anyway you could make a "gunnermike53 superclean"? you could call it "supergunner 3.0"! what do you think?
I really appreciate all the expert advice I receive from this forum. My question is I'm currently running Black Hole 4.21 voodoo and my phone is running great. My battery life is pretty important because I'm going all day and it's hard to charge during the day. My battery life is now about 10-11 hrs on an average day. Considering everything would there be any advantages with switching over to SC 2.8? I was running 2.4 and my battery would only last 6-8 hrs, though everything else was great. Should I switch to 2.8 and make any changes as far as modem or kernel or stick with what I have?
Alright, so I'm running SC 2.8 on my phone, but I still don't get audio out from my USB in my cradle, is there anyway to fix this or is it not supported yet?
There really is no way to guarantee that one ROM or combination of ROM, kernel, modem will give you better battery life. Some people have reported great battery life with superclean, other people have reported horrible battery life with superclean. The only way you will know for sure for your phone is to try different combinations, but that will be very time consuming. For now everyone is going to have to deal with the battery life issue until the official Froyo is released and the devs can get their hands on the source code and put out some custom and undervolted kernels.
Quick question, I'm running SC 2.8 my market keeps force closing anyway to fix my problem?
Hit the menu button and go settings=>applications=>manage applications=>all, scroll to market, click on it and click the gray bar to clear cache. If that doesn't resolve the problem, boot to recovery and wipe cache and dalvik cache then reboot.
there are only two ways:
1. sammy car cradle app. press the blue mute button, top right of car cradle.
2. sammy music player. play a song and press the phone button in the now playing list.
its kinda lame. well friken stupid, but better than nuthin.
Tried both suggestions they didn't work, thanx for the reply. Would I have to reinstall SC 2.8 to fix that problem?
I see "possible" eb16 kernel. It also says that it is included. What exactly does "possible" eb16 mean? Should I reflash the eb16 kernel after flashing 2.8? Sorry if this has already been answered.
Sent from my SCH-I500 using Tapatalk
I can't remember whether the other solution was to reflash the 2.8 ROM, or just the EB01 modem. Sorry.
"Possible" means the kernel may possibly allow you to tether your phone without Verizon being able to monitor it to charge you for the data usage.
stopwatch
