[Retired][ROM]Superclean 2.9.2 EA15/EB01/EB16/EC10 Based
I did wipe cache partition and dalvik cache, I did not reflash 2.9.2. It seems to be running great if i run into problems I will reflash 2.9.2. Im trying the Ultimate Honeycomb v3.1 theme it says its updated to 2.9.2
I'm also running Ultimate Honeycomb on 2.9.2 and everything is fine. You won't see the 2.9.2 in the notification bar, but tha's just because the theme overwrites that, you still have 2.9.2
Sheep Dog
how hard is it to go voodoo all the way.. what are the major differences other than a different file system ?
can i just flip to voodoo but Flashing 2.9.2 Voodoo over what i have?
i read that Voodoo is faster ..but this thing is faster now than i am..lol.
so what do you suggest?
i have the same Shark i like the honey comb fire up.. all the colors flashin cross the screen..
mine does show the 2.9.2 in status bar
Yeah I noticed that, I figured I still had it, but I do like seeing that 2.9.2 in the notification bar - it makes me feel warm on the inside!
Im running the same thing... Ultimate Honeycomb 3.1. Not seeing the 2.9.2 on the status bar either. Would be nice to see it, but doesnt matter. The theme is awesome, best one so far... Phone is running so good I wanna cry! lol
Yeah I really like this theme but I also like the VA Green Theme so I hope it gets current to this build soon.
VA Green one of my other favs! Was running that this morning till I flashed Ultimate Honeycomb 3.1 I can see myself going back and forth on these two.
Sheep Dog
To go voodoo all you need is a voodoo kernel. No wiping, no fuss, no muss. Flash the kernel via CWM, enable lagfix from voodoo menu in CWM. If you want to flash a non-voodo kernel disable voodoo in the same place, and reboot fully first. Mostly if you flash anything just flash your favorite voodoo kernel before you reboot, if you're not sure if it's voodoo or not.
I'm happy to report that since updating to 2.9.2 I haven't had any FC's with launcherpro :) One thing I did notice though, is that when I go to contacts>history, it's empty. Before, all my texts/calls from throughout the day were there, then I'd erase them.
Originally Posted by motoprof View Post
I did the first part, and icon no longer shows. Then I pressed and held the blank dock spot, selected change shortcut (no create shortcut), then applications, then contacts.
It goes to the contacts, but then when I hit the back button (second one from the right, it goes back to an identical contacts screen. When I hit the back button again, nothing happens. When I hit the home button, it goes to the home screen. It was not doing the double screen thing before, but the back button would not take me to the home screen
Have you tried rebooting? if you have and you're still having issues try wiping cache and d Cache in CWM
I did that last night. I deleted the cache, davlik wipe (or whatever that is), and reflashed. The only problem is that when I select contacts, the back button will not take me back to the home screen. This was my original problem. I have to use the home button. It appears to be the rom since I never had this issue with DL30 leak.
One issued i noticed since I flashed 2.9.2 is my alarm clock wont work. It works if I briefly test but when i set one for the next day it doesnt go off. I also tried downloading one from the market, same thing. Is this a permissions issue I need to fix or what? Any takers?
Hey Guys, I'm running latest SC version no problems at all.....Question I have is I liked the "Favorites" widget on stock version...the scrollable one that you could add a picture & either one click to send a message or to call
Does anyone have the link that I could flash or is this possible with 2.9.2????
Reactions: ttoptt
Update: nitroglycerine33 over at XDA has also posted a link for a CWM flash of the default keyboard. This fixed my problem.
Link: http://forum.xda-developers.com/showthread.php?t=985689
Thanks.... I actually noticed that last night as well. I should have posted, my bad. I really likes the look of the UC 3.1 keyboard, but I like hvaing the haptic feedback better. So, stock andriod it is for me!
Sent by use of The Force
now i remember why i gave up on LP. I used to be able to get the back button to work in the contacts but after 2.7 nothing worked for me and it would lag like a mofo after a reboot, I would have to wait a good 2 mins after rebooting before it would let me do anything. Have you tried GO launcher EX? IMO its better than LP. If you try it out you'll noticed that the back button issue will still be there BUT w/ GO EX i can promise you that a reboot will fix it. You can get it from the market and its free, also get GO notifications.
Reactions: motoprof
go back to the first post on this thread and look under patches-->flash the tw ones.
Try just doing a cache and dalvic wipe... don't reflash, just reboot. That has restored some things for me in the past
Reactions: motoprof
tnez - i have flashed those...still not seeing it. I'm running launcher pro & when I pull up the widgets it's not listed. I want "Buddies now" I thought that originally there was a flash for the Samsung Clock & the Buddies now widgets....back around SC 2.6 or so
I went to an X & came back to the Fascinate and now I can't find them to flash
