[Retired][ROM]Superclean 2.9.2 EA15/EB01/EB16/EC10 Based
just updated to 2.9.2. when i long press the right button, i do not get the shutdown menu. help
Stupid question..I'm running SC2.9.2. I selected the AOSP unlock screen. When you unlock the screen, it shows the date, time, belongs to, and alarm icon if it's set. On the belong to part, it's blank. How can I get it to show my name? Is there a setting for me to enter my name?
Thanks....
Thanks....
thats a good question. i will poke around and see what i find. ill get back to you.
Reactions: rgm1266
Thanks....
I've never seen a "belongs to" option. Is that a third party app?
Originally Posted by motoprof View Post
I did the first part, and icon no longer shows. Then I pressed and held the blank dock spot, selected change shortcut (no create shortcut), then applications, then contacts.
It goes to the contacts, but then when I hit the back button (second one from the right, it goes back to an identical contacts screen. When I hit the back button again, nothing happens. When I hit the home button, it goes to the home screen. It was not doing the double screen thing before, but the back button would not take me to the home screen
I did that last night. I deleted the cache, davlik wipe (or whatever that is), and reflashed. The only problem is that when I select contacts, the back button will not take me back to the home screen. This was my original problem. I have to use the home button. It appears to be the rom since I never had this issue with DL30 leak.
try this. this is what worked for me. Clear data on launcher pro then immediately reboot. dont touch anything. then Long press on the contacts icon, choose change shortcut, choose applications, choose phone, choose default icon. Click on phone icon, click back soft key. Long press on that same phone icon, change shortcut, applications, contacts, default icon, click icon, try back button. Then restart again. All shall be good after that! Let me know. I got to this with the help from Sharky
Reactions: Landshark
Question:
I have SC 2.9.1 EC10 VooDoo with VA Green theme installed...
I don't much care for the boot animation, and want to go back to the 2.9 boot animation with the cool honeycomb explosion thing going on...
Can I just pull the file 'bootanimation.zip' from Adryn's SFC 2.9 zip (super_frankenclean_2_9v > system > media), and load it through CWR like any other ZIP file? Or will that totally tank something? And, would I have to remove the current 'bootanimation.zip' file first, or would the newly zip'd file overwrite it???
You can place it into system/media and it will work fine.
Andrenalyne,
Are you planning a minor rev based on some of the comments and your questions today? If so, I'll wait to flash...
TIA
Mike
Well, if you flash the camera from gizmodroid, then it fixes the camera. I'm just try to catch up and see what other issues are. I was worried about the haptic feedback, but since I reflashed it was fixed.
Brand new to this whole flashing roms section. I appreciate all the help and info that you all have posted as I have read this thread up and down...
That being said- I'm stuck on trying to upgrade from sc 2.9 to 2.9.2. I'm sure its been covered, but when I flash EC10SC292x_DXC.tar using odin it is stuck on the Image section. Did I need to wipe anything before upgrading? I waited 20min unplugged, tried again and now I'm receiving the soft-brick error. Now I've noticed that when I plug in the phone my windows drivers no longer recognize the device. Any help would be great. Thanks
I use the AVG Antivirus software and it has that feature. If you have it, open AVG, press the soft menu button and choose the "Remote" option. From there you can select to show or not show the lock screen message, as well as edit the message itself. I like it. That way if my phone is locked and lost an *honest* person will be able to see my contact info to return it.
Thanks....
Reactions: rgm1266
I know it's important to do a backup through CWM before loading a new ROM. After backing up and installing the ROM and setting up the phone the way you like it, I'm assuming it's a good idea to do another backup. Yes? No?
I have everything set up how I like it and apps backed up with TiBu and thinking about doing a full backup again so that if I need to restore it for any reason everything will be just like I had it.
phone options help
just downloaded sc 2.9.2. when i try to long press the right button for phone options, it doesnt pop up. please help
The files listed on the first post u dont flash with ODIN. You download them, place on sd card and flash with CWM. Hope that helps!
When I lower the volume of the ringer the lowest I can go is vibrate, I can't silence the phone. Is this done on purpose or a glitch?
yes, the power button.
try rebooting into recovery and do a cache wipe and a dalvik wipe (dont reflash 2.9.2) reboot and see it if works
if not, I would do the same thing again, but this time reflash 2.9.2
thats the best I can think of, but more experienced people on here might know better
But, give it a try, it cant hurt
Dugoh1
