[Retired][ROM]Superclean 2.9.2 EA15/EB01/EB16/EC10 Based
It appears that when I add a theme from nitroglycerine33 onto this release,it kills haptic feedback on the stock android keyboard. I have installed a third party keyboard and told it to override system default on the vibration intensity. This seems to work to correct that issue. Stock keyboard worked fine before theme was overlaid.
Sent from my Froyo Fascinate using Tapatalk.
which 3rd party keyboard are you using to do this?
Thanks!
"Originally Posted by motoprof View Post
When I press the contacts button and the contacts come up, I cannot use the back button to go back to the home screen. I have to use the home button. I'm using Launcher Pro.
Try deleting and re-creating your contacts shortcut."
Try deleting and re-creating your contacts shortcut. =\
How do I do that?
How do I do that?
Since you are using launcher pro, I am assuming your contacts short cut is on your dock? If so, just press and hold it, select "change shortcut", then choose blank.
No go back to the blank dock spot, press and hold, select "create shortcut" go to applications and select contacts
I did the first part, and icon no longer shows. Then I pressed and held the blank dock spot, selected change shortcut (no create shortcut), then applications, then contacts.
It goes to the contacts, but then when I hit the back button (second one from the right, it goes back to an identical contacts screen. When I hit the back button again, nothing happens. When I hit the home button, it goes to the home screen. It was not doing the double screen thing before, but the back button would not take me to the home screen
have you installed any themes? Roms? Patches?
Thanks!
"Keyboard for Android 2.3+" by Steven Lin, which is the paid app. Here is the link for the paid and free. I think it is worth a $ for the paid one, Good luck!
Free: https://market.android.com/details?id=com.moo.android.inputmethod.latin.free&feature=search_result
Paid: https://market.android.com/details?id=com.moo.android.inputmethod.latin&feature=search_result
Update: nitroglycerine33 over at XDA has also posted a link for a CWM flash of the default keyboard. This fixed my problem.
Link: http://forum.xda-developers.com/showthread.php?t=985689
does anyone have a theme applied on 2.9.2 that is running smoothly. Im currently running VA green theme 1.9.2 and it seems pretty smooth, I did notice on the notification bar it changed 2.9.2. to 2.9.1. Is that because it is not updated to the latest version or did i screw something up?
Question:
I have SC 2.9.1 EC10 VooDoo with VA Green theme installed...
I don't much care for the boot animation, and want to go back to the 2.9 boot animation with the cool honeycomb explosion thing going on...
Can I just pull the file 'bootanimation.zip' from Adryn's SFC 2.9 zip (super_frankenclean_2_9v > system > media), and load it through CWR like any other ZIP file? Or will that totally tank something? And, would I have to remove the current 'bootanimation.zip' file first, or would the newly zip'd file overwrite it???
Just a warning for you but using a theme for a version back may replace some of the updated files with modified ones from the previous build, thusly reversing some of the improvements. The odds of it mattering seem slim but still, I would wait till your theme of choice is up to speed.
Have you tried rebooting? if you have and you're still having issues try wiping cache and d Cache in CWM
reloaded 2.9.2 today and everything works fine. i have somehow kept the Market which i thought had been removed..but its here anyways.. i checked my GPS and it showed exactly where i was in my house which has a tin roofed front porch.. and i am happy... i did have to remove the EB16 from my fascinate as it went wild changing apps on its own.
i heard someone say they used the 2.9.2 to voodoo.. at this stage can i just install the Voodoo 2.9.2 and be a Voodoo phone or is there more work involved. i dont wanta push my luck, so far all is well and stable for now.
the theme hasnt been updated yet. Like sheepdog said you're now running a mix of 2.9.1 and 2.9.2 but mostly running 2.9.1 cuz that theme is based on the previous framework.
Yeah thanks for the heads up. I think im going to flash one of the themes that is current with this build.
Flashing over with a different theme can be problematic. You probably want to wipe cache partition and dalvik cache, and reflash 2.9.2 and then flash a theme of your choice.
I did wipe cache partition and dalvik cache, I did not reflash 2.9.2. It seems to be running great if i run into problems I will reflash 2.9.2. Im trying the Ultimate Honeycomb v3.1 theme it says its updated to 2.9.2
gaganprasad
