ARCHIVED: [ROM] - 11/6 - CleanROM 2.2 - Fast, Stable, Clean!
Status
Not open for further replies.
Re: [ROM] CleanROM 2.0 - 7/23 - Overclocked, AdBlocked and WiFiTe
I just attempted to install the update, having an issue with the sdcard, an cannot install. Enjoying this rom very much.
So I just started using this rom, and I am very impressed with it. I've used every rom and this is by far the fastest. But at my lockscreen. Using a pattern, if you don't do it correctly. The phone reboots. Please fix?
Sent from my clean optimus using Tapatalk
I cannot reproduce this on a fresh flash. Its working as it should be for me. I failed to enter the correct pattern 4 times and it put up a 30 second timer. After the timer expired I tried 4 more times and the timer pops back up like it should.
Maybe something you have installed is doing this? Can you list all the apps you have installed and I can download them and test them.
If anyone can reproduce then please tell us what you did to reproduce it...
Im a little confused... Did you get it going?
Hmm I've got the steel my ellegence theme. Go launcher ex. Smart keyboard pro, and wave launcher
Sent from my reborn optimus using Tapatalk
Can you post a link the steel my ellegance theme. I can find the rest.
I'm getting a cannot format sdext error failure at line 4. Im sure it's a problem I created elsewhere but if you could help I'd appreciate it.
Maybe you have a corrupt SD Card? Not sure if you have a card reader you could put the card in and format it. If so try that. If not, restore from a Nandroid back up then connect the phone to a PC and try to format it that way.
EDIT1: Can you tell me what ROM you were using before this?
EDIT2: What recovery are you using also?
I was running the 1st edition release of your rom. Running Amon RA recovery. Had a 2nd sdcard laying around, threw it in and dl'd a fresh version, but still had the same issue. Could it be an issue with the way its partitioned?
Reactions: scrosler
I know what it is. Its the way the recovery is handling the sdext format command. I made changes in the 2.0 ROM but I guess the change is not compatible with that recovery. I am going to recompile and remove that command. Very easy fix! I will upload it soon if you would like to try?
Ok, try this version its CleanROM 2.0.A - Should resolve your issue!
EDIT: Make sure you wipe data, etc when when in recovery, like with the prior version. I modded the script to no longer do it on this revision.
Thanks for the speedy replys, downloading now and looking forward to getting back on it. I prefer the way your rom runs to the cm7 offerings.
Reactions: scrosler
Great, let me know if that solved it!
Reactions: Strikur
It did, easypeasy install. Im liking the new battery icon. Have you got a source for themes and icons? Guess im picky but I havent found any of the readily available ones to my liking.
Good to hear! There are no special icons in this ROM. As far as the battery mod... I did it using the UOT Kitchen. I just used it to modify the stock 2.2.2 framework-res.apk.
Re: [ROM] CleanROM 2.0 - 7/26 - Overclocked, AdBlocked and Hotspo
New version released!
CleanROM 2.1 - 7/26/2011
Change Log
Version 2.1 - 7/26/2001
Added native Hotspot capablities via the Hotspot Widget. You now have infrastructure mode!
Removed WiFi Tether due to the addition of Hotspot Widget
Added Quick Boot (reboot). Great app to reboot the phone!
Updated to Google Music 3.0.1.33.
Updated Voice Search 2.1.4
Updated HOST file​
Change Log
Updated HOST file​
If you could add a notification bar power selection (ie: toggle GPS, wifi,sound, brightness) like ath3nos' ROM I would certainly enjoy it :)
Sent from my LG-LS670 using Tapatalk
Re: [ROM] CleanROM 2.1 - 7/26 - Overclocked, Ad Blocked and Hotsp
I see. But the point of the ROM is to be CLEAN with little mods. I want to keep it as close to stock / pure Froyo.
I will be creating a full blown custom ROM that is themed and I will add that in. But that will be later.
Thanks for the feedback!
Reactions: Kifwalu
Status
jr212
