Go launcher ex does the same thing
i just installed 1.3 and it works pretty good for me, thanks. it seems like none of the mods (battery indicator, crt shutoff) are there though?
Thanks for the new boot image, i noticed you said you dont have to wipe anything, but then you said to reinstall the kernel after the boot image, its fine to install the kernal without wiping anything too?
Also do i need to reflash amphetamas after doing this?
over at xda there is some touchwiz apks![]()
the mod which shows the % left for the battery doesnt seem to be any of those, that's what i'm looking for.these
ZVJ-clock-normal-mod-v1.3.zip - Flash this to move the clock back to the right side of the status bar.
mod_no-buttons-wake-GB.zip - Only power button wakes the phone
mod_stock-GB-button-layout.zip - All four front buttons and power button wake the phone.
_________
powermod.signed.zip are all on op
Just a quick question if it hasn't already been brought up. I flashed 1.3 and did the mods. Everything works fine and battery life is decent. I tried my hand at ADW Launcher with the rom and it works as usual but crashes or freezes. Anybody else or am I having some kind of problem?
I had already flashed Hydrokernel at the start. I'll give Launcher Pro a shot and see if it happens again.
FYI if you flashed hydrokernal THEN flashed to mod I did for the boot.img it will also RESTORE stock kernal (boot.img includes the kernal and at Drews request we do not include his kernels in our roms and mods)
Quick way to check, go into nofrills cpu control and see if you can clock over 600, or go into about phone and see which kernel it lists.
Close to getting touchwiz working it boots and everything but when it sleeps and I try to turn back on only a grey backlight appears but we r working on it
Sent from futuristic optimus s
