ARCHIVED: [ROM][4/05/12][4.0.3]MIUIv4 for OV! By Team A.P.P
Status
Not open for further replies.
Re: [ROM][ALPHA][4.0.3]MIUIv4 for OV!
Remember- if you're getting Roaming Indicator Off in the status bar, service/3g is working. Just needs a little boost :)
Have the old OV.
3G isn't working for me, and the hardware keys don't shut off. Camera doesn't work and the USB icon is just there.
Just giving some feedback, not really getting any FC's besides the one on startup :D
3G does work, the icon just doesn't show up.
Does anyone know how to adjust clock speeds in this ROM?
The music is a problem I've had with all miui ROMs I've owned.. and to fix time, simply uncheck automatic time zone in settings>date and time, and select your time zone.
I REALLY didn't want to do this, but I feel that it will take some time to get the phone to stop FC'ing.
So, as an alternative, I'm going to post this in the comments only, as it is still alpha worthy.
DON'T TURN ON AIRPLANE MODE. IT SEEMS WHEN THERE IS NO SERVICE, THAT IS WHAT IS CAUSING THE PHONE TO CRASH.
Although you will be greeted with a phone crash at startup.
As always, if data isn't magically working, then it is the misbehavior that we occur during the regular CM9, and just toggle data (I haven't had any phone FC's with this yet)
But I want you guys to leave feedback as well; and I want you to do a new thing.
If you have had previous errors with other ROMs, and have errors with this one that haven't been reported, don't report them. It's usually a bad flash, download, etc.
And, if you have a bug, please report which phone you have - the new OV or old OV. Thanks LeslieAnn ;)
Download- Alpha4-radio,ph.zip
facebook updated
im extracting some of the cxool apps i wanna play with harmonia
well like the file manager ask anyone i experament what do i have to loose :D
im going to log cat what happens after i switch on airplane mode
Hmm.. this seems very interesting. Thanks for the info. I'm going to look into taking down that app.
You sure it had the letter E by it? Because those are signified as errors
it might ve i cant seem to get adb to connect so i can look at a bigger screen :|
im gona reflash a few times or redownload but ive had this issue after the 2 alpha its a little strang
Status
tarntime
