[ROM][4.19.2011] Das BAMF 1.5
It's debloated in terms of the Verizon crap but still has everything there for the full Sense experience
I did a straight upgrade from 1.3.2 to 1.4 and all went well. The only problem I am currently having is that Voice Search doesn't work. It Force Closes when I try to use it.
I may try a full wipe but Ill wait to see if there is a fix or update before I do.
Got the fix from the XDA forum. If your getting this error go into the Market and look for an update to the Voice App...turns out there was an update and that fixed my problem. No wipe needed.
Can you go with basic, stock sense for a theme? I don't really care for the black theme.
+1 It seems that this rom is the closest to stock HTC with Verizon debloated, but the extras is too much for my taste. Anyway possible you can cook a non-themed version of this rom please? :-\
ive been running stock for little while now...feel like its time to dip my toes into ROMs...
gonna try remix after work...does anyone know if u can put icons to left or right on Home screen where it says battery percentage?
I would also love a non-themed version of this. For some reason the 5 column app draw seems a bit laggy and I'm just not feeling the black market. But great work on what you have done, I hope I don't sound ungrateful. Keep up the good work!
Reactions: Dukins
Yes. There is room for 8 icons and the clock on the home page which is what I'm running
Sent from my ADR6400L using Tapatalk
Set CPU Question
I am a little confused about the use of set CPU here. if i were to download and install set cpu this rom takes care of the rest as far as over/under clocking?
You use set cpu to customize how you want the clocking to take place.
Ok, So I just installed the rom... one thing I'm not sure about is flashing the kernel. Can anyone help me flash the kernel for this specifically? Thank you much.
If you flashed the ROM you flashed the kernel. It's included in the zip file.
So what is the difference between 1.4 and 1.4 remix? Currently running 1.3.2 and it works pretty good.
In that case i'm confused as to why I don't seem to have the option to change the cpu clock speed. setcpu still has my max at 1024
Are you running a different kernel and stock; or a different kernel and different rom?
Nope. I installed it as per directions, user data cache and dalvik wipe then installed the entire zip from sd. I ended up redoing the whole thing again this time after a factory reset and seems to work beautifully. Completely worth the time.
Strangely enough, my favorite part may be the smooth visual for the battery when it's charging haha.
Odd, I know with the stock rom you need to disable perflock in order for sedtcpu to work correctly.
This is the first ROM I have tried on my TB, while no stranger to ROM's on other devices I wanted to play it safe with the TB given the LTE radios.
On I did a full proper wipe of data/cache/dalvik and once it rebooted up I noticed I had 2.29GB of space left. I know when I had the stock ROM running and removed the bloatware I didn't want I had at least 2.51GB free.
So exactly what just took up 300MB of space considering the Verizon bloat was taken out so really 500MB was removed?
WendMcCom
