[ROM][4.19.2011] Das BAMF 1.5
Just wipe cache and dalvik and flash 1.6, but make a backup in case. If it doesnt work right you can always do a data wipe with the other two next time you flash.
Ok, from ROM manager I chose install ROM from SD card.
I told it to wipe cache and nuke Dalvik.
When it rebooted, it had the right ROM, but all my stuff was gone.
I'm thinking I needed to boot into recover, then choose to flash it from the SD card to keep all my info/data?
I did make a backup of my phone just this morning, which I'm restoring right now.
I just don't feel like setting everything up all over again.
Love BAMF 1.5 remix. Smooth and fast!!
Yeah i never use rom manager to flash anything. Boot into recovery mode, manually wipe cache and dalvik, then choose zip from sd card and flash.
Thanks as always zero. At least I have a pretty fool proof backup/restore routine...:)
Unfortunately, I've had to make use of it.
Will try later on!
So I loaded up 1.6 beta2 and the patch for the call recorder while watching the ball game on Fox this afternoon. So far I haven't noticed any issues, but I really like the new Das BAMF toolkit.
It includes some great features such as:
- change CPU speeds and select CPU governor settings
- ad blocking toggle
- the command line shell
- select whether the boot sound is enabled without having to use the command line shell
- select whether the boot animation is enabled
- toggle between 3G and 4G
- select between the stock and Sense lock screen
- plus much more!
If you're going to give 1.6 a try, definitely check out the new toolkit.
ChrisAndroid
