[ROM][4.19.2011] Das BAMF 1.5
Facebook for Android is not syncing contacts. Neither is Twitter for Android. Are those supposed to be working?
Edit: Facebook just decided to sync. 24 hours after install if someone wants a timeline.
Edit 2: Twitter did sync about 4-5 hours after Facebook did.
Mine battery life has been rock solid with the new radio over 3G and wifi. Going to test it with LTE tomorrow-Sunday so we'll see how that goes.
Flashed new radio and running BAMF 1.5. Set CPU set to smartass 245-1420. Running like a champ so far. Battery life is great and device is stable. Thanks Adrynalyne!
noob
I am getting my thunderbolt today and i have never rooted or flashed a rom
I was just wondering, is it possible to use bamf remix while stilly using htc sense? (Is this a dumb question?)
I want to get all the benefits that bamf provides but still use the htc widgets and skin.
BAMF has elements of Sense built into it, so it will allow you to run widgets and skins and such from Sense. There are many other ROMs that are "Sense-less" that will remove these elements all together.
I think there might be a sense-less version of BAMF somewhere, but I don't know for certain.
I've read Adrynalyne say over at XDA that he will have auto brightness fixed in the next release. I Hope it's soon!
Das bamf is sense based, but there is a "de sense" package you can flash that will make it appear less sense-like.
You can find links to these things here:
The Official Thunderbolt ROMs and Kernels Listing (Updated 4/28/11 12:45 PM CST) - xda-developers
It's just way too bright under low lighting conditions, and the phone was like this out of the box in case you hadn't noticed.
OK, I might not be a total noob but I am slighly confoozled. I flashed the non-themed ROM and could someone let me know if I need to flash a radio and/or a kernel?
Under the about screen, under Kernel Vers. I have the following:
2.6.32.21
Thanks for any help.
2.6.32.21
Das Bamf has a kernel built in (i believe 1.5 has the 4.4.2 kernel).
You don't have to get the new radio, it's up to you, but if you want to you need to download the file, check the md5 sum, and then rename the file pg05img.zip and place on root of sd card, reboot to bootloader, and then approve the install. Follow that by deleting the pg05img.zip file when you're done. There are more detailed directions if you conduct a search of the forums.
Thanks for the reply and the information. I seem to be doing good on 1.5 un-themed and all is working good for me. So if there is no need, then I think I'll sit still for now and enjoy it as is.
Thanks again.
So could someone help me figure out whats going on here? I have 1.5 still in its zip file on the root of my SD card and when reboot into clock recovery and install zip from SDcard it starts and then says (bad) and wont install.
Am i doing something wrong here?
Forgive the newbie question. I have my phone how I like it...smooth, fast, reliable.
But I can't resist the urge to tinker. Running BAMF 1.5 remix currently
Will this ROM overlap 1.5...or do you have to/should you wipe it clean and start fresh?
TIA
Just wipe cache and dalvik and flash 1.6, but make a backup in case. If it doesnt work right you can always do a data wipe with the other two next time you flash.
edit:
btw, i have downloaded 1.6 beta 2 three times, and each time the file downloads at 223 mb but it says at the mirror that the file is 213 mb. I went looking for a checksum at xda but couldn't find one so i'm going to wait to flash 1.6
jacketempire
