[ROM][4.19.2011] Das BAMF 1.5
I flashed 1.5 in cwm (no wipe), powered up, rebooted into hboot and loaded the new radio. Haven't run into any issues yet. 3G signal seems to be much stronger and hopefully I'll get to test LTE on Thursday.
Good to know, sometimes when you flash the rom first and reboot, the rom won't work with the old radio, and you get a boot loop, have to do a battery pull, and then flash the radio. But if it worked for you that sounds good to me.
Flashed again this way and confirmed that it works.
*wiped cache and dalvik however.
was runnin 1.4 remix fine. ran the new radio and the 1.5 rom 3 hrs ago.
I noticed everytime I restart my clock widget on the home screen, it disappears. along with my tapatalk widget.
but if I long press where the tapatalk widget was it comes back. unfortunately, the clock won't.
any solutions?
any solutions?
Did you clear cache and dalvik before upgrading?
did you do a full data wipe as well?
Everything is running smooth as butter right now, and the animations are awesome. I came from the remix, and I prefer this non themed look overall.
No real opinion on the new radio thus far, but I'll report back later. Thanks again Adrynalyne!
The boot and transition animations when you go from screen to screen. They're not something you would notice unless you didn't have them before. I didn't have them on my last install, so I appreciate seeing them again. You can further tweak the speed of the them in spare parts.
Yeah, remix too.
Just flash in hboot and be done with it. No muss, no fuss.
You da man, man!
This is for you:
Reactions: zero neck
I downloaded the 1.5 and loaded it on my TB about 3 hours ago without the radio fix. My phone seems to work fine currently - so how will I tell if my phone needs the radio fix?
ok so I got this Rom and loed it till I find out I cant use my Internet. it keeps asking me to use my USB!!!! That Sucks BAD any ideas here?
BobCat6767
