[ROM][4/30/12][4.0.4][AXI0M] CMPLX by DroidTh3ory
Re: [ROM][4/11/12][4.0.4][AXI0M] MORFR by DroidTh3ory
Another question is whether these feature packs can be used concurrently? Unless you really didn't like something about one of them, why wouldn't you want to run all of them?
I believe that was asked on the HIVE and the answer is no. Like a theme, it'll overwrite.
What he's doing makes sense though; he's allowing the user to pick the features so that they can choose what type of feature experience they want.
I like the idea I want to try all the roms, this will make it easy to do so and see what features they have to offer.
Oh I understand the philosophy, and this should satisfy the crackflasher's appetite. You just know you're going to find 2-3 features from each you like best, but you either have to pick one, or flash continuously.
Yeah, I'm actually in that boat. Love AOKP's nav bar mods (well not the images, but adding the search key, colors, etc.), but I hate their status bar/notification dropdown toggles. On the other hand, I am madly in love with the CM9 power widget. In a perfect world I can have both (and presumably would once CM9 reaches RC or Stable release stage).
Btw it's currently uploading. As always, wait for the go ahead!
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
Re: [ROM][4/11/12][4.0.4][AXI0M] MORPHR by DroidTh3ory
GET IT!
Edit: MORPHR booting. Boot animation is SICK. I may wait to flash a module, waiting on CM9 and have no interest in CNA lol.
BTW, I beat DT in updating a thread. I can has cookie?
Reactions: 2defmouze
Re: [ROM][4/12/12][4.0.4][AXI0M] MORPHR by DroidTh3ory
I'm probably flash it while waiting at my daughters soccer practice. I downloaded the CNA module, but really don't want it. I may flash it just to see how it is to flash between modules.
lol it's a meme, the whole ???? ==> Profit thing. I can remove it if it's too confusing.
Installing the CNA Module; someone said it had my beloved CM9 power widget, so a flashing I am going.
EDIT: Module flashed, but apparently I can't download from the Market anymore? Just perpetual "Downloading..." Thoughts?
EDIT EDIT: Another user has this issue as well.
EDIT EDIT EDIT: Don't flash a module yet. If you do, make sure you've got your downloading out of the way. DT himself did not have that issue, but everyone else seems to have it--at least those who have seen my post on HIVE.
Last EDIT: Files have been pulled from rombot, I'll keep you guys updated. Everyone and their mother (other than DT lol) is having the download issue with CNA. Essentially, you flash it, go to Play Store, and the download is stuck downloading in perpetuity. Forcing it from the webstore also does not work. I am Nandroid-ing MORPHR right now and am waiting to see if we'll get a new file. I hope the Play Store doesn't block my Restore, b/c it'll be third today lol
Where did he put the OP? It isn't in the thread he started at the Hive.
Hopefully it is only a module update. I decided to download all my apps before I flashed the module. Hopefully I won't have to do this again.
I listed known bugs in my op.
As of ten minutes ago he had not updated the morphr thread.
They were taken down.
I've been wanting to try AXI0M's ROMs for a while. Do you think a fix and CM9 or KANG modules are coming soon?
I'm hoping. At first he seemed somewhat hesitant in believing there was a PlayStore issue--I guess it worked for him? And then EVERYONE had the issue. I presume he's figuring out what creates that issue...one member reported that if you went to the playstore in your browser it worked, but I personally tried forcing it in both Chrome and my Chrome on my computer and nothing worked, so who knows.
I posted screens in the OP. I flashed different softkeys, so when I flash the new MORPHR I'll post up a stock screen of that. The lock screen search key bug is also pictured.
anuragkushwaha2025
