[ROM][4/30/12][4.0.4][AXI0M] CMPLX by DroidTh3ory
Yo dmm (advisor, OP)
One thing in the op that I am curious about. In your notes at the bottom it says:
•If you're using ZipThemer for softkeys, you must use the module's .zip to update/configure edify.
I use zipthemer alot and are you saying you gotta configure zipthemer again after the install?
Every time you install a rom or theme you must configure or update edify to that zip. If you don't install the module, do what I did and update to base morphr.
Otherwise it may not install, or worse, boot loop.
To update, go to menu and follow the prompts.
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
Re: [ROM][4/12/12][4.0.4][AXI0M] MORPHR by DroidTh3ory
I've installed zipthemer couple months back with numerous roms and updates (aokp, gummy, liquid, pz etc) and have only configured it once and no probs. Will keep in mind though if I run into probs. :)
Keep in mind I play things safe ;-)
What's the clock / weather widget shown in the first morphr screenshot on page 1?
Beautiful Widgets with a Roboto clock skin (probably clear, but there's a few of them and I have them all) and the weather skin is either MC Weather or something like that. I can grab it and let you know a bit later.
where is the AOKP Module? and which AOKP build is it?
The AOKP module has not yet posted. I haven't checked the HIVE in a couple of days b/c of DT's family tragedy.
The only module available was CNA, and it was buggy (see OP). I presume he has to work out the kinks first, and then it'll be posted. Also, he always uses the latest/greatest version, so it'll be B31 unless a milestone comes out before then.
The AOKP module is not built yet. The CNA module caused problems with the play store so the whole set was pulled by the Dev. The dev has since has personal issues to take care of, so the base module was put up on several mirrors for people to play with at their own risk. T&P for DT.
Reactions: dmmarck
Yup. I'm actually restoring Patient Zero M1. Reading on the HIVE that 121 was the hotspot franco kernel, so I'm hoping I still have that lol.
i just flashed patient zero m1.
just want to know why you like it so much?
and does it have beats audio in it?
(1) Stable, fast, reliable.
(2) Yes.
How do you turn the beats audio on?
The Beats Audio is integrated. It's always on--at least for stuff like Play Music. For Spotify, Pandora, etc., it's not really apparent.
For a difference, listen to one song on one of those services and then listen to it--if you have it--through Play Music. Big difference.
You can also use DSP Manager to tinker with a variety of things. I've been listening to a lot of Grateful Dead shows recently, so I prefer the Virtual Room (in DSP) to be stage and the equalizer to be rock.
... I've been listening to a lot of Grateful Dead shows recently, so I prefer the Virtual Room (in DSP) to be stage and the equalizer to be rock.
Thats funny, couple of my roommate's friends were down visiting to see Further last night, said it was a great show.. never listend to dead much but I think I'd enjoy em :)
I'd kill to see Furthur!
Is there a mirror for the CNA module? None of the links for any codename stuff are working...
Yes, rombot is still down. I can host it a bit later, and I'll update the OP and post a link when it's done. Be mindful though, there be bugs ;).
what do you mean 121 nightly is the hotspot kernel?
is it the best?
Ian Breeden
