[ROM][5.07.2011][ED01]Community Rom V1.3
Flashed 1.5 yesterday and having much better results so far than with 1.4. Everything just seems a little faster.
Wiimote?
Absolutely loving this rom! Is there any way we can add the bluetooth controller functionality. Id like to use my wiimote to play emulators and such. I know so far only a couple roms allow it but I would never switch from this.
LP plus. Nemesis and the guys at IRC just told me some voltage settings to use. I think I'm just going to stick with ComaVolt though.
What were the settings? I'm willing to give OTB another try if I can find some settings that work. I like the idea of being able to tweak my voltages.
Just installed v1.3 wiped everything first.... everything is working fine except I can not open the dialer... it just force closes every time ... any thoughts ?
Whenever I used launcher pro on evil fascinate or super clean 2.9 I would end up with a freeze at 11:03am every day and sod. I would try without lpp. I tried lpp out last night on com rom and had the same indicators on it (force close on rebbot, etc) that I did on evil fascinate and super clean when it caused issues in the past. I would try a different launcher and see if that works. I love lpp, but it was the cause of my pain in the past.
Sent from my SCH-I500 using Tapatalk
My wife's Fascinate did that too. I have no idea what caused it, but the only way I could get it to go away is to RTS and update to ED01, then reflash KB 1.3.
1000/800 @ -25, 600@ -50, 400/200 @ -75. Not much undervolting there which is why I am probably going to switch to ComaVolt. But I'm going to give those settings a try for a few days and see how they do.
I already tried it once before without LP and still got SOD. I'm trying again this time after I used navenedrob's ext4 formatter.
Just rooted for my first time yesterday, and I'm loving it :D OUTSTANDING job guys. Only one FC on my skyfire, thats it!
I do have an issue on my gallery though. It will only display any pictures that I have taken or loaded into my SD after I flashed CommRom. I can scroll through left/right one at a time, but when I am looking at my pics or DCIM folder, all the images are blank. Anyone else see this?
I'm running CommRom 1.3 with the included kernel, and GO Launcher EX with a Honeycomb theme. I also have Custom Launcher Icons, so I've changed the theme around and messed with my dock a bit. Thanks in advance guys :)
I have seen numerous people posting they were having problems with the facebook app. The general consensus seems to be that the facebook app sucks, and friendcaster is the way to go. Seems everyone using friendcaster is getting all their notifications. There is a free version and a paid version for like $4. As far as I can tell from just a quick peek, the only difference between the two is ads and no ads.
WOOT WOOT! I've never heard of friendcaster, but it's downloading now :)
thanks!
Can' t thank you enough! Freindcaster works wonderfully!
Having issues with the ECO1 modem on comrom. Keeps disconnecting 3g and it takes forever to restart the connection. Have to make a call to *611 to reconnect data. Should I look for a modem update or am I missing a setting somewhere?
I just came to comrom from evil. I can't get any for the symbols to show up in the status bar. I did get the time to show up but it stays at the time when it boots up. I have messed around in the tsm parts but can't get them to work. Any one know what I can do? I am also running the extreme green theme.
try rechecking everything that you want in TSM, scroll down to text color, make it white, tap the white circle to make it white, then go back to your homescreen and reboot.
I cannot get 1.3 to work at all. I get the Samsung screen...have to revert back to 1.0 then upgrade to 1.1.
Also, is anyone else having issues with automatic backups from Verizon? It crashes every time for me. *EDIT* Worked this time under 1.1
Settings-language & keyboard- choose the keyboard you want as default. Should not change between applications unless you change it or you got something wrong elsewhere.
EnigmaDragon
