[ROM][5.07.2011][ED01]Community Rom V1.3
I have had this happen in the past... you can uninstall an app - then install from the market and the rest will show up...
Ty much that worked! Hadn't heard that solution before :)
Is the cwm from the pbj kernel available as a separate patch do you know?
Sent from my SCH-I500 using Tapatalk
I have not seen it offered as a separate recovery.
Bah what a pain. Have to odin 2.5 to flash some of the older patches. Like the power amp car cradle patch then re flash the kernel to get the cwm back
Do you have a link to the patch.. more than likely I can write a script in edify to install it..
And ty in advance for even trying, it's greatly appreciated!
Sorry it took a minute..
Here is a standard installer package.. This should work.. Link
Ty much! I'm going to learn how to do that when I get home from holiday. Where would I go to learn how to do it for myself?
Believe it or not.. I learned it theming.. In theming the developer or ROM development uses a system of scripts to get files to copy from the zip file to specific directories on the phone.. Same goes with applications, kernels, data files, settings, and other files..
I see the dev for Com Rom 2.0 recommends flashing it with CWR 3.0, but that it should work fine with CWR 3-30 All. Once on Com Rom 2.0, and the themes/kernels compatible with it, is there any reason to continue using the older CWR? Are there patches (Amend script) for Com Rom 2.0 that still require the older CWR? Also, can anyone confirm/deny that Comavolt is compatible with Com Rom 2.0?
Thanks in advance. I'm learning as I go and I could never have come as far as I have without all the fine people here and at XDA!!! My hat is off to all of you!!!
Will it work with CWR 3-30all? I thought it was mentioned before that 3.0 was preferred? I just DL'd the zip for 3.0.
Anyone know about the thinkfree and nuance apps? I assume these were removed as they always are but will the zips to add them back work? The last ones were from Evils Fasc. rom and were listed as edify scripts. I know I have been using Sunder74's themes and I think they are edify too. All have loaded on the CWR 3-30 all just fine.
Thanks,
No reason to go back.....just use 3.0 from here on out.....
Thanks,
The patches will work, Those r removed....I I flashed thinkfree earlier, just stick with CWM 3.0 from here on out.....
Anybody have the hex color code that matches the GB theme for the clock? I think someone posted here before, but I can't remember it.
Something else I noticed since flashing 2.0. My screen will time out randomly, this instance happened while I was going to write a text. When I power the screen back on it won't recognize my input in swype. I have to back out of handcent and re open it to start texting. Just an odd glitch.
does anyone know where i could get CWM 3? i believe im still on CWM 3-30 All and i wanted to update before i flash Comm Rom 2.0
pamatika
