Bfascinated
- Jan 31, 2011
- 89
- 6
- 0
You will not use Odin to flash this. You can install over nonvoodoo.. enable lagfix on the next boot to make voodoo or put a Voodoo folder on your sdcard with disable_lagfix file in it.
How's battery life?
Sent from my SCH-I500 using Tapatalk
I've never used Voodoo before (I've only heard negatives in the past) is it worth switching?
Likely you have been told the worst. But if you are not comfortable using voodoo do not attempt until you are ready.
How will this ROM differ from Voodoo & NonVoodo? Is it simply a speed difference?
Do we need to update to the newest CWM before we flash this Ultimate Community Rom?
Also it states GPS framework wipe data or can we flash over current without data wipe?
Is there any way I can change it to touchwiz?
just flashed ...was on sc2.9.2v w/ ec01 kernel, just wiped partition/davlik & flashed ...it was smooth sailing, everything is looking Good, no problems..I was already voodoo'd out but this seems a little more snappier/responsive than before, also the gps locks on quicker too ..kinda miss the colors on the settings screen, not sure how I feel about the all white background in the text messaging app, ...anyone else have that little orangeish color in the corner in the task manger?
You are the man. Always here for everyone's questions...You do not need to update to CWM 3.x.. You can flash without data wipe.
I think he meant to get rid of the launcher.
I appreciate it.
Would you recomment flashing the latest CWM anyhow?
I completly understand. So have you flashed this community Rom yet?I am not ready to make that leap until a majority of the ROMs and other flashable items are switching to Edify.. I have all of my boots and shutdowns almost ready to go.. as soon as ROMs fly-edify.. I will switch.
anyone have a link to that thread that explains the voodoo vs non-voodoo that was on here. couldn't find it when i tried searching. i've never used a voodoo rom before but have been enjoying SC2.9.2 for the past 2 months. considering this one but want to know alittle more about voodoo.
Thanks
