[ROM][5.07.2011][ED01]Community Rom V1.3
I completly understand. So have you flashed this community Rom yet?
Still waiting on a clean download.. first attempt was a fail from filedropper - I had 95% of it and it dropped the link.. I have 7:37 on my second attempt.. once I have it on the phone I will be able guide folks better..
I am not ready to make that leap until a majority of the ROMs and other flashable items are switching to Edify.. I have all of my boots and shutdowns almost ready to go.. as soon as ROMs fly-edify.. I will switch.
someone was saying in IRC that most edify will still flash in 2.5.1.X i might be wrong on that but pretty sure thats what they were talking about.
Reactions: jalin725
Took the plunge!! Never used Voodoo before. I am popping my cherry! :eek:
EDIT: "your lagfix is now activated" She said.... The suspense is killing me, just boot already!!!
EDIT2: the word android on the screen. I hope this is normal.
They are correct - you can flash many if not all edify scripts in CWM 2.5.1.x.. It is just time consuming to get all the zips repackaged..
Reactions: bigjobber69
Just flashed via CWM over Evil Fascination 3.3.2 just wiped cache and dalvik and everythings running smooth as silk no FC's or anything. Thanks Adrynalyne and all the devs for putting this out!!
Reactions: jbr05ki
Yes normal... Doing the install now..
Reactions: curley
three questions: how big is the file size, can this be flashed with odin, and how to i use the touchwiz launcher?
size 159,356kb ...don't need odin to flash, just drop onto your sd card and flash in cwm, wipe partition and davlik & make sure you have lagfix enabled before flashing...not sure I understand the touchwiz ?
Loaded and running. Startedfrom scratch, I went back to stock fix EB01 and then flashed it. Wanted to wipe the slate clean with a new ROM.
Curly all is normal took about 3-5 mins for it to boot up all the way for me. congrats on popping the cherry.
currently i am running the version of CWM that came in SC2.9/SC2.9.2. i recently downloaded 'cwm-recovery-ALL-3-30-FIX.tar' that landshark posted but haven't flashed it yet. is that the one i need before flashing this community rom? also dumb question but when its said 'internal SD card' thats not the actual SD card is it?
Good to know cuz I just did a full wipe and installed that evil rom as hwell. Thanks.:confused:
HOLY CRAP!!! This RUNS AWESOME ON VOODOO!!! Having only ran non, there is a noticeable difference! AND DADDY LIKE!!!
Why have I not done this before???? :p :D :D
im on sc 2.9.2 and still with the eb01 modem. Im assuming the answer is yes, but do I have to flash the ed01 or ec01 modem in odin before flashing the community rom?
Reactions: kriscris
hussondros
