Landshark
- Jan 11, 2011
- 4,434
- 1,382
- 113
How's battery life?
Sent from my SCH-I500 using Tapatalk
It's been out less than 2 hours how are we supposed to have any kind of a feel for how the battery life is?
How's battery life?
You can flash either modem before or after the community rom...i suggest EC01 it gives me better GPS performance.im on sc 2.9.2 and still with the eb01 modem. Im assuming the answer is yes, but do I have to flash the ed01 or ec01 modem in odin before flashing the community rom?
three questions: how big is the file size, can this be flashed with odin, and how to i use the touchwiz launcher?
If I already have the EC01 radio, is there any need to flash it again before/after flashing this ROM? I'm thinking no, but wanted to double check.
Sharky, you know anything about how to use "Voltage Control" im scared...LOL
So I flashed this over the ED01 package, enabled lag fix and rebooted. Now I'm stuck on the ANDROID splash screen and I keep feeling the FC vibrations. Any ideas?
For those outcasts that want nonvoodoo
Make a Voodoo folder on your sdcard, and put a file in there named disable_lagfix before installing this rom.
Giddyup!!! Looking forward to something new & finally coming to the voodoo party!
currently i am running the version of CWM that came in SC2.9/SC2.9.2. i recently downloaded 'cwm-recovery-ALL-3-30-FIX.tar' that landshark posted but haven't flashed it yet. is that the one i need before flashing this community rom? also dumb question but when its said 'internal SD card' thats not the actual SD card is it?
No, I will be learning as I go too. Go to nemesis2all's kernel thread over at xda, there is a template showing you the recommended settings and many people have posted screenshots of their settings. Start with the standard and see how it works for you.
You don't have to flash the EC01 modem in ODIN before, but would probably be a good idea. There is no stand alone flashable ED01 modem yet, hasn't been leaked.
Where are you seeing internal sd card? And the cwm-recovery-all-3-30 is the current correct cwm you can use to flash this. That cwm will flash both amend and edify scripts. As Jaekar99 said, there aren't enough ROMs, themes, etc. based on the edify script to justify switching to the orange cwm 3.0 put out by times_infinity, but we will get to that point sooner than you probably expect.
