[ROM][5.07.2011][ED01]Community Rom V1.3
There is not currently a way to ODIN this ROM, it must be flashed in CWM. Once you do that, there is a CWM flashable patch in Adrynalyne's superclean thread for the TW launcher. It was designed for EB01, but may work. If you get any problems you can always just flash the full community rom to wipe away the TW patch.
Crap - I meant flash, but thanks for the tip on finding TW
That's what I thought, but what does that look like with these patches? Flash 1.0 again, and go through the patches or is just the patch good enough? Thanks for the help.
you would need to reflash the patch as well... (just 1.2 since it contains everything in 1.1 also)
2... I'm sure you will see improvements! Make sure you charge to 100% (with the phone off) boot into recovery... wipe battery stats... and reboot. Obviously, battery life varies from phone to phone, but this has been BY FR the best battery life I have ever experienced. Good Luck!
for a while clearing battery stats through clockwork wasn't working and we needed to use terminal emulator to wipe them. Is it working again our should we use bstats in terminal emulator still? Thanks in advance again.
can i do a complete wipe of my 32gb sd card and the program still run ok..if i lose everything i dont care as long as i dont lose CWM Com Rom and whateve else makes the system work??
its 11:55 pm ish in SE TN.. someone say yea or nay
wiping batt stats is working in the CWM-recovery-all-3-30-fix. You will not get the confirmation it worked like when the phone reboots after wiping batt stats in terminal emulator, but it is working.
Reactions: Brettdacosta
if you have the latest CWM, then yes... bstats works
formatting your SD card will not affect CWM or your Rom (unless you have a nandriod back-up, then it will be wiped)
Reactions: papa54
welp i just formated it, thx a million.seems something had messed up.. cause before the flash i had 12gb free, now i have 29.7 free..thx again
If I don't want the ad blocking in 1.2, can I just delete the hosts file from the .zip?
CommRom v1.2 notifications
Man that thread us getting long! Anyway I've stopped getting notifications for kik and word feud. Notifications are turned on so could this be a problem with the apps or the rom? Love everything about this rom so far keep up the hard work.
im trying to get the android keyboard back. i put the LatinIME.apk in my /system/app folder with root explorer, but im not sure what to do next.
i rebooted, but the android keybaord is still missing
My bad, sorry. After you place it in the system/app folder, click on it and you should get an option to install. If you don't see an option to install by clicking on it, the option is there with a long press on the apk
i tried to install but when it finishes, it says application not installed.
I just read killahamsammich's post again and as long as you extracted the apk file out of the ROM zip file, then placed it on your sd card, then copied it to your system/app folder, it should work. Don't know why it's not working for you.
h1awke
