[ROM][5.07.2011][ED01]Community Rom V1.3
I tried looking in the comm rom thread and nemesis2all's kernel thread and couldn't find an answer for what was changed except possibly voodoo 8 sound added.
I just wanted to say that I think so far this ROM update has been awesome. And probably the best one they have put out.
I just have a simple problem dunno if its been discussed these forums posts can get quite large fast!
On the COM ROM even if I turn off the auto-rotate. Either from the pull down, the toggle button or through Settions > Display Settings.
The screen still auto-rotates, any ideas fixes?
There's a non rotate patch.
Weird issue with icons
I'm running the 1.1 patch and keep running into my home screens being blank for up to a minute or so after waking the phone up or closing an app. Has anyone else run into this and if so, what fixes it? Love the ROM, but that's starting to get on my nerves. And so far, my wife's phone, also running 1.1 seems to be running much smoother.
installing system/app apk's via cwm
might not be the best way to do it but it works for me...
i was able to get the SC29 mms and market apks loaded in the comm rom. i have to say i love this rom. first time voodoo and i understand why ppl like its performance.
Answered in another thread by bigjobber, but apparently the new nemesis kernel includes cwm 3.0.0.8. Looks like it's time for everyone to start making the transition.
I switched to launcher pro and it fixed + I prefer launcher pro plus anyway. Also there is no issues with the calendar in launcher pro. The thing I like with launcher pro plus is u get an unlock code when u go pro, so if there is ever a back up issue or loose the app somehow, allu do is reenter the code to unlock again.
For those having the calender issue...
The amazon app store has Business Calender app (which is a very nice app btw) for free today, normally costs 5 bucks or something. Snag it while you can!
Thank you for 1.2. I was missing ad blocking. Already snagged docs.
Docs is what will propel an android tablet into the mainstream.
thanks man..I like Jorte myself..also worth a checkout..
Does this issue with the calendar exist if your using a third party calendar synced to your google calendar?
You might check your voltage settings...make sure they are as they were when you flashed the rom first time..
Also check the OP he put out 1.2..which has some improvements..
do we need the battery stats script posted by Adrynalyne a week or so ago..to get it to work correctly?
The script is already included in the ROM. Right from the changelog in the OP:
Changelog (1.0)
Voodoo only.
ED01 based.
Debinged entirely, debloated.
Edify compatible.
Awesome kernel from nemesis2all, including voltage control support included in Rom.
Supports accelerometer calibration.
Stay awake options enabled in Development settings.
Reboot options from power button.
Dial Up Networking mode enabled in Wireless settings.
GPS enhanced framework(requires data wipe initially).
Modified GPS.conf.
Volume keys wake phone.
Car cradle supports aosp music app.
Camera supports power button to snap and geotagging.
Lockscreen mods, including music controls.
Configurable top bar mods to hide battery, show DBM, and more!
Aosp music, Aosp mms app.
Working long press of search.
Gingerbread inspired theme.
Auto rotating Launcher.
Busybox 1.19.
Sqlite3.
Gingerbread keyboard.
Latest swype, themed.
Download Crutch enables downloads of all types.
Nexus shutdown animation, ringtones, etc.
rw, ro, bstats,fast_media, default_media and fxpms scripts.
Microbes live Wall from Nexus S.
ahh yes..don't know how I overlooked that language I don't normally speak in a long list of other things..
:p
I haven't had the chance to mess with the voltage yet, I may try some of the profiles people have posted here and see if that helps. Thanks!
AAArrrggghhh!!! Why am I now having so many problems trying to load up Kang Bang so I can make an ODIN package? Getting massive FC's on boot. Does everyone else still get the Nexus boot animation with Kang Bang? I keep getting just the word android on the middle of the screen with what would appear to be a spot light moving back and forth across the word.
joelkmason
