FrankWhite77
- Jan 15, 2011
- 153
- 6
- 0
AAArrrggghhh!!! Why am I now having so many problems trying to load up Kang Bang so I can make an ODIN package? Getting massive FC's on boot. Does everyone else still get the Nexus boot animation with Kang Bang? I keep getting just the word android on the middle of the screen with what would appear to be a spot light moving back and forth across the word.
loaded the 1.2 patch, which removed ThinkFree and installed Docs. Never used Docs so thought I would give it a try. Only thing bothering me is that ThinkFree supported PDF as well as MS office files. Bloating up with the Adobe PDF reader seems counter-intuitive to me on this great, sleek ROM... what light PDF viewers are suggested?
Finally found an answer by nemesis2all as to what was changed in the new kernel:
Fixes and upgrades that were not ready when 1.0 was released. Upgrade to voodoo sound v8.
Scheduler change, patch that allows minimum frequency to be changed and stick thru reboot. Other small changes check my git or touchwiz thread for more info.
Good luck! Its a long process, but for the most part very easy to follow... let us know how it works!
OK... Admittedly I took a break for a while but I finally got it done. I am in the process of rebooting for the last time and Voodoo woman is talking to me so I know I am good.
I am curious about two thing. the first I'll find out in about 2 minutes.
1. Since I had ED01 and then flashed COM ROM, did it downgrade my radio?
2. Battery life.... I am almost dead right now and will go to sleep shortly and charge overnight. This is the sole reason I an trying your method. If I get the battery life you did, and it is not a quirk, I will be loving life (and you!).
Thanks for giving me hope!!
EDIT: ED01 is still there!!
What exactly is the sound fix that voodoo is supposed to be able to handle? I mean is it in the output speakers out the headphones or the in call quality?
Also... How do removing themes work? I mean I really want to try the green one out for com rom, but don't want it to screw things up for advancing further in the future. Any thoughts? Thanks in advance.
not sure on the voodoo sound.... i know you can still use Voodoo Control to increase the headphone volume... other than that, I am not sure
as for removing the themes... if you don't like it, boot to recovery, wipe cache and dalvik, reflash the rom and the theme should be gone
