[ROM][6/26/12] CyanogenMod 9 - Official Nightly & RC Builds!
Re: [ROM][4/4/12] CyanogenMod Nightly Builds - OFFICIAL!
can someone post the 04/04 changelog? It will not load at my work and I'd like to know what tweaks they did. I don't see that any of the "Preference Stubs" have filled in to add more features.
For some reason under 4/4 it's blank? There are 2 things for "the next nightly" though. Anyone else seeing that?
I just decided to quit being lazy and pulled it up on my phone. yea there is nothing under the 04/04. The next nightly says they are fixing LTE support...I myself haven't experienced much problems with the LTE
Me neither...I also have the 4.0.4 radios, so it'd be interesting to see what they do there.
Are the 4.0.4 radios a separate flash or is it included when CM9 went from 4.0.3 to 4.0.4? I've only flashed CM on any of my phones and I usually don't do much tweaking or addl flashing other then the Google Apps because I know that's a necessity.
But I hear other people talking about flashing different Kernels, etc...gets a little confusing
Flash separately. The radios are usually not "included" with a rom unless it explicitly says so. Therefore, the radios are always constant--you have what you have unless you change them.
do you have a link for the radios? I use rom manager and I don't see that the radios are on there
found em...I was still on 4.0.2 radios. It'll be nice to see what a difference this will bring
Re: [ROM][4/7/12] CyanogenMod Nightly Builds - OFFICIAL!
Updated for yesterday's builds!
For radios, a great package is featured in my AXI0M thread--it's called the get ready package. I've had zero problem running the 4.0.4 radios (and that package specifically) across 5 different roms at this point.
I suggest wiping cache/dalvik before flashing them. In theory, you want to flash them before you flash a rom (so if you're going to flash 4-7-12 nightly, do ALL wipes, flash get ready, then flash the rom).
However, you don't necessarily "need" to do it in that order. The radios really affect nothing with the rom, so you can just go in and flash. Also, I believe there was a 4.0.2 to 4.0.4 radio thread in this forum a while back. Check that out; there should be links to the 4.0.4 bootloader + radios package.
Thanks. I got the radios but the didn't include the new bootloader. Is there an advantage or disadvantage of not updating the bootloader?
Honestly, I have no idea. I know the package usually contains both, but why the bootloader + radios come together beats me.
Re: [ROM][4/10/12] CyanogenMod Nightly Builds - OFFICIAL!
Updated with the 4/10 Maguro build. Also, CM fans, if you didn't know, here's the new CM mascot, appropriately called CID.
http://www.cyanogenmod.com/blog/introducing-cid
Re: [ROM][4/12/12] CyanogenMod Nightly Builds - OFFICIAL!
For the folks on the nightly express, the OP has been updated with the 4/12/12 release :)
I used to rock cm on my x but have been using bugless beast on the nexus. Might have to give cm a run this weekend.
I've run ~7 different nightlies, and each has been impressive. The new boot animation is awesome. I haven't flashed this one (yet), but I presume Cid will be on it (and if not, then soon enough!).
Flashed this up tonight. I like it. Hopefully my battery likes it.
If not, try franco. I know that's like the "go to" of GN roms, but really, it's fantastic w/ CM9
Anyone having call quality issues? I've noticed sometimes mine will make a loud beep and then there will be a lot of screeching through the convo. I don't make many calls but just noticed it on this nightly
StevieD49
