[ROM][6/26/12] CyanogenMod 9 - Official Nightly & RC Builds!
Re: [ROM][4/12/12] CyanogenMod Nightly Builds - OFFICIAL!
Anyone having call quality issues? I've noticed sometimes mine will make a loud beep and then there will be a lot of screeching through the convo. I don't make many calls but just noticed it on this nightly
Might be worth flashing the updated radios if you have not done so, that are the 4.0.4 versions. Have not heard of issues specifically, but most times it pays to be up to date on them, especially with the LTE authentication troubles still being worked through on the VZ side.
This. The updated radios are where to be.
Updated radios someone last week. I switched to lean kernel recently. Could that cause issues? I'm on Franco now, but like I said, I don't make much calls to really see if it's resolved
While kernels are awesome, they're the source of a majority of issues. Well, them and improper wiping habits ;). Make sure you let them settle after a day or so!
Thread updated with the new 4/18/12 builds for both GSM/CDMA!
Re: [ROM][4/18/12] CyanogenMod Nightly Builds - OFFICIAL!
I'm experiencing the best battery life I've ever had on 0417. I didn't realize 0418 pushed out already!
Have you noticed any changes between 417 and 412? The change log is huge lol
Hey guys I've noticed an issue with my CM9 nightly, at least I dont' remember it in stock. In some of my folders on my home page, the order of my apps will change randomly, between the order I set them and another random order. Anyone else notice this?
I haven't had that issue occur. Are you using the stock launcher (Trebuchet)?
I've noticed this also. It's not a big deal to me, but its just weird how it moves random apps to the top of a folder for no apparent reason. I've also been flashing CM9 nightlies for the past 3 weeks or so without doing a factory reset first. I haven't had any other problems, but I'm sure if I did a reset it would take care of this minor issue.
Yes i'm using trebuchet. Once I load a new nightly, or sometimes randomly, they will be ordered correctly, but then randomly two of my folders will become disoraganized, and sometimes come back randomly too. It's only two folders of my 7 or so too, just to add to the randomness of it.
I've had it happen a few times. Noticed it in my games folder but didn't think much of it
yeah my Google folder and my Games folder....
I find it annoying because it will take me longer to go through my folder and find the app i wanted now, plus from a design point of view I choose my first app based on how often I use it and how it looks as the app the folder shows...
Same here, but I haven't noticed any of my front apps moving so I've just let it slide
no update for 4/22 yet :P I hate reading the change logs over at cm9 ;P
I'm not sure if it dropped after you posted, but the OP has been updated with 4/22 builds ;). The change log is its usual mix of rubbish with more rubbish thrown in lol
haha yeah, after i posted :P I was just teasing anyways, i think I upgraded as soon as the new build was up.
Reactions: dmmarck
There has been an update to the GAPPS file too on April 22nd. It isn't yet listed in the OP.
Reactions: dmmarck
alyass
