[ROM] ACE ROM v2.0 (No Further EC05 Development)
Would you like to see the CIQ Removal in the next release of ACE?
  • Total voters
  • Poll closed .
After flashing this last night (excellent ROM btw), I must have done something else to remove the extra wallpaper options you put into the ROM. Is there any way to get those back?
Thanks!
The three wallpapers shown on the OP are loaded into the provided AMLauncher, they can't be removed unless you replace the Launcher with something else.
Long press on your homescreen and choose Wallpapers, you will find them there.
@all, just an update before everyone starts asking yes I will be working on getting a new update out very soon. Now that it appears Syndicate/Bonsai have the no-CIQ working good and things are looking better I will look into adding those features into ACE and some other things.
So sit tight and I will keep everyone posted as development continues.
Paul,
How does this look?
It appears to be about average for this ROM and setup. I don't personally use benchmarks, yes I've tested stuff I flash but just for fun. I go off real world use and not what a testing program tells me..
If your phone is working as you would like, and performing how you want then I wouldn't worry what some benchmark program tells you. We actually joked around among the Advisers and a few Mods here at AC a while back about benchmarks and one of the mods is running the Nexus S and those boast some crazy benchmarks and even he said it doesn't feel to run any better than a phone only posting half the benchmark stats.. It all comes down to how does it run.. Fast, smooth, good battery life?
So far so good, looks smooth. Restored a few of my apps. and things seem to be normal. Awaiting to see how the battery life is. I appreciate your work, THANKS. BTW, this ROM seems extremely stable. I tried another just to try it and there were a lot of issues. THANKS!
WHOOPS! That would be the issue then. Switched it with ADW.EX. Any way I could get those wallpapers in a .zip file or something? It's my wife's phone, and she loved those.
You can download them directly from the source, the person who made them for me.
Here is a direct link to the thread starting with the wallpapers. Look at the link and the next post or two down..
ACE Wallpapers
Reactions: WrlsFanatic
Installed last night, working great so far.
Thank you for providing what Sprint and Samsung could not. Looking forward to the future releases.
I really like your rom im currently runnin syndicate frozen 3.1 so ill pass until you update and remove ciq...but you really helped out a lot with the rotation lag thank you
"Rotation Lag Fix:
Download Terminal Emulator from the Market
Type the following
su (press enter and allow root access)
/system/bin/sensorcalibutil_yamaha (press enter)
Then it will ask for you to calibrate. I usually lay mine flat on its back with keyboard open and then press enter. Back out of program and power off the screen then wake the phone up. Lag rotation fixed."
Hi everyone this is my first post as a member so bear with me as i am still learning how to do this correctly. If I do something wrong please let me know. First I want to say thank you to Paul627G for the ACE ROM V1.7 that i flashed to my epic last night and its running very smoothly love the speed and stability of the ROM good job! Thanks for putting up with me guys have a good one!
Oh before i forget i have run into one issue with the ROM but i'm not sure if its the ROM or the program but i'm having problems getting privacy star to sync with their servers so i can use the non-trial version that i bought it keeps telling me when i first open it "A server error has occurred. Please try again at a later time." If someone has found a fix for this please let me know i'm going to keep searching for one and see what i come up with. Thanks
Ah thank you!
I apologize I should have done some more reading before complaining, I love the ROM so far!
Like the idea of an update soon although aside from blue tooth i am totally happy with what you have already
paul - do you have a list you are working for possible updates beside the carrier iq?
i would assume we would have to wipe and reflash? what is the best way to backup your app data?
still loving it. i do not have to charge my phone during work now and the overall appearance and feel is so much better than stock.
