[ROM] ACE ROM v2.0 (No Further EC05 Development)
Would you like to see the CIQ Removal in the next release of ACE?
  • Total voters
  • Poll closed .
The message your getting has something to do with the Genocide kernel your running, I see it listed in the message. You could try to flash the regular Duel RFS/EXT4 kernel and then try that app again.
The Galaxy Tab email should work, as long as its CWM3 format which if you got it from TER or here in this forum we have it in CWM3 format.
BTW, I will post the link to the Dual RFS/EXT4 Kernel in the 2nd post shortly.
Great. I will try the Dual RFS/EXT Kernel later today to check that out.
and yeah the Galaxy Tab email i have is from TER so it is CWM3.
Thanks a lot.
Paul,
In order to use the Duel RFS/EXT4 kernel, do i just install over with CWM 3006 or do i have to do a wipe with CWM 3006 and then run the kernel?
any plans in including the smiley hack in 1.7? (still trying to do it on my own, but I'm messing up somewhere =[ )
@ESlogic, I can take it into consideration. I have a few other surprises in store for "key remappings".
hey paul :) great rom, odd works at first, but just had to restart the phone and everything was fine, i was getting random Vibrations as if i the AM launcher fC's or something else, don't know, never got a pop up window.
btw, can i still use the TERMini theme 1.8? or will you be making one similar to it? I liked how the transparency and the dark theme looked :)
i don't care about the icon changes, just the theme itself was phenomenal :)
Yes I'm working on something.. Haven't completely decided the exact specifics. I'm not much of a themer but I can pull off a few things.. I'm trying not to copy anything I or Ragnarokx did with TER just out of respect to the ROM itself. TER deserves it... It was and is still a great ROM and I had alot of fun working with Ragnarokx on it.
Anyways yes TER Mini Theme will work on here, I ran it for the first few days I was using EB13.
As far as your vibrations and stuff, not sure what thats about.. First I've heard of it...
Reactions: Kikoshi
Ahh... All this talk about how awesome this rom is makes me want to switch and try it... But I don't want to have to go thought the hassle of trying to make gps work in dk28 again if I don't like it.... ya'll have me torn :(
Sent from my Epic 4g using Tapatalk
Give in... do it!!!!!! I would have to say it is very comparable to TER. I few tweaks here and there, still a very solid rom.
biggest question - im about to do it... so if someone sees this soon... please answer ASAP- download link that is working for that dual kernel??? (and/or will my genocide .03a work???)
haha. well i know what you mean. thanks :) i love what underclocking does for my battery life. im actually booting phone up in CWM on EB13 as i type this. its taking forever to boot into it for the first time and convert to EXT4 (guessing thats what its doign).... ::crosses fingers:: heres to it all going well!
k.. so i got ACE running... and i was wondering.. do i have to flash the Sprint VM zip and bubble sms zip from TER, or are those two features working properly on this ROM? (and if they arent working correct, would the TER zips even fix the problems)
Good question as those are two items that I installed back onto of TER.
Well until you mentioned it I hadn't checked it out. I don't get a lot of missed called going to VM. Anyways, I just checked and called myself and all I got was a message notification and when I clicked it I was sent straight to Visual VM.
So I guess the bug we had in DK28 doesn't exist on the Voice Mail in EB13
Wowow. Love ACE. Thank you Paul! Just enough feel o TER to not seem like a totally different OS, but definitely its own unique rom (like comparing windows 7 to windows vista.) definitely faster. Not sure if that is just eb13 v dk28 or TER v ACE, but it faster either way. Dunno about battery life yet want to give a day or two analysis to compare... but its sleek, smooth running, fast, and so far compatable with everything I've done to it. (Genocide, font, and a few other little flashes). I definitely won't be botherng to go back to dk28 now that I got this running. Thanks for all the help, and I definitely look forward to more updates for this! :)
Sent from my Epic 4g via Tapatalk Pro
Has anyone noticed better battery life with the genocide kernel (0.3a) under ACE than the stock kernel? Im doing an informal test on it now. Screens been on bout 20 minutes (studying chem, dont have time to mess with it), ran 3 benchmarks (Quadrant twice and Smartbench once), sent a few texts, talked on the phone for about 3 minutes, and it has otherwise been idle. Sitting at 90% after having been on 3 hours 48 minutes. Seems very good.. Consider that it comes off the charger at 97% (due to bug not on ACE/genocide)..
ACE ROM v1.7 coming very soon with many updates....
Will it be a flashable upgrade to the existing ACE v 1.6 or will we have to backup and reflash?
Either way, great work- ACE rom is definitely one of the best, and the best imo..
@GSF1200S, This will be a completely new ROM, due to the modifications that were added.
ihtasham
