[ROM] ACE ROM v2.0 (No Further EC05 Development)
Would you like to see the CIQ Removal in the next release of ACE?
  • Total voters
  • Poll closed .
yes it is a zip file. It is to be flashed in CWM. Double check your placement of the file on the sdcard.
Thanks. Really weird when i downloaded it, the file was just GTalk Restore_CWM3006 with no file type at the end. I'll just add a .zip at the end of it.
Reactions: Paul627g
Sorry for the dumb question but in order to flash the battery fix do I just flash it as if it were a rom or as an update?
@Paul627g
Hello ... After the ota update was pulled I decided to go ahead and root my phone .. Being new to this stuff, A little scared of damaging my phone I stook to just reading... I rooted my tablet (coby) nothing grand but it helped me learn...
So I rooted my phone and I installed this rom lastnight and I just saw the zips on the second post... So from what I am understanding from an earlier post , you will just put updates in the second post ... The rom # 1.6 will stay the same for now and these zip updates will become part of the 1.6 rom once I install it into my phone ?
Also maybe not for this thread but , In CWM when i first used it I used my volume control to go up and down thru the menu and the home button to choose items. When I went to install this rom it wouldn't work that way... I had to use the keyboard... Is this the way it's suppost to be ? Maybe i missed something that stated this will happen...
Anyway thank you for your time and ROM....
You should be able to use the volume up/down to move through CWM and use the camera button to choose items.
@Paul627g
Yes when you flash (install) these zips in the second post they become part of the ROM updating it. I will eventually release an updated ACE ROM v1.7 but in post #2 is a few restores and changes that you the user can make until the next update.
When navigating in CWM all you need to do is use your VOL UP/DOWN to scroll and Camera button to select.
Anyway thank you for your time and ROM....[/QUOTE]
For those that switched from TER to this ROM, how does it compare and how does battery life compare? I love TER and this sounds like a good ROM to switch over to, to ensure that I have the official Froyo release.
@Paul. Nice to see you extending yourself. You were very helpful in the TER thread and I look forward to trying this ROM out soon :)
@DaveInFlorida, looking forward to having you onboard with ACE ROM.
I've used this rom for about 3 days now and I see a significant improvement in battery life compared to ter 1.5. Through fairly heavy use on ter I'd get to about 15 percent battery after 8 hours. On this rom with the same usage I'm getting to 40 percent by that same time. YMMV
@markot86. Thanks for the info. With TER, if I take my phone off the charger at around 6am I still have around 30% left by 11pm. Of course depends upon the usage, and to be honest I probably don't use my phone that heavily. But, if ACE gives better battery life than TER then that is a bonus :)
I would also say I definitely have seen better battery life with ACE over TER. I do think it's just a hair (and only a hair, sorry Paul!) slower with moving between home screens, but that's not really a big deal and I'm not sure if that's due to ACE or the differences between dk28 and eb13. Overall I'm loving it though.
Sounds good to me guys... Don't tell Ragnarokx, he will get jealous.. LOL. Really though, that's great I'm glad to hear your enjoying the ROM and the battery life is living up to your expectations.
Hey guys just moed to ACE ROM 1.6 from TER.
The battery life is very similar on both ROMs. over all i still like TER a little bit more because i had just gotten used to it ha but im sure Paul will make this one a great ROM as well.
The only problem i have really had its with the words with friends app. When i open the app i get the following message "http://androidsdk.ads.mp.mydas.mobi/getAd.php5?sdkapid=28986&auid=A0000024545CE7&ua=Mozilla/5.0%20(Linux;%20U;%20Android%20Genocide_0.3a_EB13_OC/UV_Kernel;%20en-us;%2020SPH-D700%20Build/FROYO)%20AppleWebKit/533.1%20(KHTML,%20like%20Gecko)%20Version/4.0%20Mobile%20Safari/533.1SPH-D700&mmisdk=3.6.3-10.10.26.a&mode=live&adtype=MMBannerAdTop"
Not sure what this means.
Also do you know if the Galaxy Tab email zip will work with this ROM?
The message your getting has something to do with the Genocide kernel your running, I see it listed in the message. You could try to flash the regular Duel RFS/EXT4 kernel and then try that app again.
The Galaxy Tab email should work, as long as its CWM3 format which if you got it from TER or here in this forum we have it in CWM3 format.
BTW, I will post the link to the Dual RFS/EXT4 Kernel in the 2nd post shortly.
webdesigner
