ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Spent a couple hours on AOKP today. Found the problem that prevented startup. It was a bad/corrupted timezone database. Of all the stupid things in the world, who would have thought it was that, or that reading a timezone database could crash dalvik?!?!
Well, I learned a good bit about debugging dalvik native method issues, anyway.
Sooo... that means it's likely that alpha8 will be dual AOKP/CM9. And I'm no longer totally frustrated and pulling my remaining hair out trying to figure out why dalvik was crashing.
So I'm gonna go play with AOKP now and see what all the fuss is about... :D
Best news I've heard all day :D
Sent from my LG-VM670 running AOKP using Tapatalk
Reactions: glarepate
Re: [ROM][ALPHA] quattrimus CM9 (ICS)
so what does it mean by it will be AKOP/CM(? it will have stuff of botrh?
I haven't been able to get build 28 to boot on my kindle fire for the life of me, I wonder if that's why.
Have fun playing with AOKP. it's basically cm9 with ics reloaded and much more. It's the egg mcmuffin of roms. :)
I have a problem where sometimes the time isn't updated when I look at my lock screen. After a while it'll just jump to the right time. I'm on A7
This happens to me on any ROM. I assume it has something to do with similarities in the way we both set up and use our phones.
@tdm I was digging around in the dexompiled framework and discovered that there are two high resolution wallpapers we don't use that are consuming almost 1 MB. Just thought I'd throw that out there. They are located in /Res/drawable-large-nodpi/default_wallpaper.jpg and /Res/drawable-xlarge-nodpi/default_wallpaper.jpg
Sent from my VM670 using Tapatalk
Reactions: tdm
So AOKP is having the same home button issue as the latest CM9 build on my phone and my Galaxy Player. I guess it's time to track that bug down and kill it. Other than that, AOKP seems to run as well as could be expected. Nice birthday present for me. :D
@cammy: this means I'll release two ROM files on the same day, one CM9 and one AOKP.
@pbailey212: I took zoneinfo.dat and zoneinfo.idx from cm9 to fix the issue. They get installed under /system/usr/share/zoneinfo or something like that.
@anthonycr: I have a more aggressive file remover now, it will remove a lot more of the unnecessary resources.
Hey tdm di dyou get the phone issue worked out on AOKP? It was force closing anytime i tried to make a call or anytime i tried to recieve a call.
I really hope not to be rude or disrespectful in any way but when are the going to be released :$
Sent from my LG-VM670 using Tapatalk 2 Beta-5
That's pretty sweet, there's so much that's unnecessary in there unfortunately. I don't like deleting stuff because it doesn't decompile correctly after you delete it.
Just placed a call, no FC.
did you rebuild it ? Or is it still the same basic rom you started with? Because everyone i know that has flashed the rom from gannons first port of it had the same phone fc issue.
Thanks I can't wait to get home and try this tonight
Status
jeffnachatilo
