ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Is wifi working on AOKP? Couldn't get it working on cm9 earlier and I think I would like the theming options in AOKP also. I have it downloaded and will flash shortly, but don't really want to flash back if wifi doesn't work...but that's all I got right now.
Sent from my LG-VM670 using Xparent Purple Tapatalk
Wifi works just fine for me, worked from first boot.
I also saw that camera doesn't work at all on AOKP.
Reactions: chellebelle
if you had to guess when a beta/rc1 build of this will be released, do you have a general timeframe? I want to try this rom but I have a feeling its going to be alpha for a while...
Based on what I'm seeing, the code in CM wont stabilize for a couple months. AOKP will probably stabilize sooner but who knows. In the meantime I'll be trying to fix MMS and the camera, and get my ICS kernel going.
no root in aokp… anyone else or only me?
I don't have root either...anyone know how to fix this? Wifi works...would like to keep it and play around with it but hate that I can't restore apps cuz I have no root :(
Sent from my VM670 using Xparent Purple Tapatalk
I tried gingerbreak to reroot it but it didn't take
What are you trying to do? If the rom seriously doesn't have superuser app and a good su binary, why don't you just install it? You still have your custom recovery, right?
Does any one know of a kernel that supports VPN ( TUN / TAP) which I can use with this rom? An app I want to use needs it, and the kernel provided doesn't have it... ):
Installed superuser app but when I try to update binary it fails because it can't find currently installed binary...any help with this is appreciated, I'm about to flash back to backside though :-/
tdm, if you're around, any advice on how to get root back on aokp? Otherwise the rom is superb!
Status
websitedesig117
