ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Aokp, no reboots
sent from my device using XPB ICS Tapatalk 2
It's throwing a null pointer exception, so it's probably trying to access an index in an array that doesn't exist. Doubt it's going to help a whole lot, since logcat won't tell you exactly what it was trying to access.
This space intentionally left blank.
The thing that threw me off was that it looks like it's trying to connect to "localhost", which makes no sense. Maybe that's normal, IDK, its just what stood out to me.
Sent from my VM670 using Tapatalk 2
By the way tdm, AOKP is AWESOME DUDE!!!!!! completely done away with cold as ice. I'm gonna stick with the cm9 for ov from now on, Thank You.:):thumbup::thumbup:
Reactions: tdm
I see what you're saying. I know nothing about how 3g works in a networking sense though. So you think it's still trying to access data over wifi?
Not necessarily, it doesn't work over Wi-Fi and won't download for offline play either.
Are you merging Theme Chooser into the next build? I really love a few of the themes and was wondering.
The themes don't really work right now because they're not made for mdpi. I tried a couple and they didn't look right.
Sounds like Jasonevil might be making some for mdpi but there's no ETA.
Sent from my LS670 using Android Central Forums
Noooooooo tdm please dont give up :( .....you gave me a awesome reason to keep my ov, :) please dont give up, thanks for all your hard work!
Those looking for a10 please check the 1st post.
Or use the search bar
Sent from your mom's phone.
Hey TDM, here's an idea. Drop the banhammer on people that keeps constantly asking for ETA's on updates, so that you could focus on polishing up this ROM. Just a suggestion. I'm as excited as the next person for this, but enough is enough.
Reactions: clodfelterac
Just wondering, would it be possible to use the tablet mode tweak on our devices? I know it would probably be pointless but I was just wondering if it can be done.
Sent from my LG-VM670 running Cold as Ice alpha10f using Tapatalk
Yes, quattrimus will work on the OS just as well as ColdAsIce works on the OV. The only hardware difference is the buttons are swapped. However, there are potential issues with the baseband, 3G configuration, and MMS configuration.
It's much easier to run ColdAsIce, that is made for your phone and it already has the appropriate configs.
The OV users running ColdAsIce are just overly anxious. ;)
I actually tried running your aokp and It got stuck at the boot logo?
Edit: nvmd, just took ~10 minutes to boot. 3G + mms and baseband don't matter to me because I'm upgrading anyway :-). 3G works!
Reactions: tdm and Glenar
Status
BrüZZi
