ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Actually there are CM9 themes but they're mostly hdpi and the theme Chooser has to be built in (I think)
Yes. I've tried a couple mdpi theme chooser themes, buy they didn't work well yet.
I guess there's a new feature in the cm9 nightlies that allows full theming so expect some theming goodies soon. :)
Sent from my LS670 using Android Central Forums
Reactions: cmerlyn
Been running Quattrimus for 24 hours. Working great. 3g was a bit spotty, but i was out in the country today. Still can't figure out how to move Facebook and twitter to my sd card.
Sent from my VM670 using Tapatalk 2
This is mine on aokp one week strong
I'm having issues with Play Store crashing occasionally. Also Navigation doesn't seem to work at all. Crashes whenever I open it. Maps works fine though.
BTW I have my CPU at 245/768 on InteractiveX and it's been running smooth like cream. ICE CREAM!!! YEEEEEEEAAAAAAAAAAHHHHHH.
Reactions: tdm
Wish I could find the cause of my random semi constant restarts...
Wonder if it has to do with extended battery but I doubt that..
Eliminate overclocking, set back to stock values and Ondemand. Dont use setcpu. It's known for reboots on ics. See if that helps, then slowly add back in overclock.
I can OC to 806min/806max on aokp a10pre1. I guess i have a superphone.
hey do you think you could port or make an app like the backside updater for this it woud be amazzing?!? :p
Battery was getting low, thought I would check how long it's been going. Almost two whole days. Pretty doggone good IMHO.
Quattrimus CM9 Alpha 10. O/C 480/806 w/SmartAssV2.
Status
LocaXion
