ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Tdm, I flashed this rom and it freezes before it even boots. Any ideas? Btw its aokp.
OK this may sound stupid but do I need to do a complete wipe when I'm flashing this new version from the last version of CM9? Or do I just need to wipe the cache and dalvik cache, flash the ROM and gapps? :P thanks in advance
It seems that more people use AOKP..does it have any advantages? also if I flash aokp, can I just wipe cache and davlik cache?
thanks for all your work tdm, this rom is the only reason why I'm not longer desperate for the Triumph. :)
Reactions: tdm
You should always do a full wipe
But then all my data would be gone right? and I'd have to reinstall apps?
if cm9 doesn't have any major disadvantages vs aokp, I think I'll just leave it. anyone have any opinions on this?
Did the developers building the ICS rom for the triumph stop working on the ROM or what happened?
Reactions: cpcollector
It still doesn't boot, it freezes in the middle of it. I did a full wipe and everything.
tell me more, please.
There is a thread on AC about Leslie Ann's handy utilities for prepping for a new ROM and for upgrading to a newer version. Both are flashable zips, and do three wipes of the appropriate areas. Saves time and prevents mistakes like accidently formatting your sd-card, which a couple of us have done. LeslieAnn did a very nice job of them, recommended.
Actually, you no longer need to re-install apps. Quattrimus moves them to your sd-ext folder if you have one. Do go back and read about it. All I have to do is restore app data. Even Swype is there right from the beginning. Major time-saver.
Status
DannaOgle83
