ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Please erase this post if it's already been covered, but I searched this thread looking for answer, but have yet to find one. I see it's been touched upon, but has it been solved, browser loading a white screen, but in the preview(closing windows) it shows the website. Also, I saw people having issues with Facebook loading a white screen, again, I searched through the thread and didn't find an answer, but I'm having that same issue with Instagram, sometimes it loads perfectly, but other times it doesn't. It's like my notifications don't show, but my feed does. I'm sorry if someone already talked about this, but I did do the search and I feel bad if I repost. Thanks ahead of time guys!
Set your user agent to desktop
Reactions: Ilovefarts
Hey can someone on AOKP test out my Slate theme? I got an error report from an SG2 owner and I want to make sure it works with AOKP and its just not hdpi compatible.
I'll test. Where is it located?
Sent from my Cybertronian QuattrOV using Tapatalk 2000 (Now With Teleka-Typing!!!!)
Did you try checking both of the memory options under Settings > Performance? That seems to have cleared up the white screen issues for me. Not sure if it's just a coincidence or not, so I'd be interested in knowing if it works for anyone else.
Thread immediately below this called "[CM9 Themes] Slate, Afterburners - Mdpi" the downloads are from the market. I just need to know if they apply or if there's a compile error for aokp. Thanks :)
Reactions: Badboytoast
I thought TDMs build of AOKP doesn't have the Theme Chooser implemented yet. :confused:
ETA's kill puppies. Sent from a ______ with Tapatalk
Idk... Im not running quattrimus I'm running CAI so I was just asking in case it did.
Nope we don't have it on quattrimus yet. I'd guess it'll be in the next build tho. Alpha 10 is done now and as far as I know from reading, 11 will have a fresh sync with cm... That should mean theme chooser will be there I think. Of course this is mainly an educated guess on my part.
I'm not sure if it's implemented either, let me restore my backup and find out. :)
I completely forgot it didnt have it... also totally forgot im running a sprint rom.
I'm guessing the Chooser is absent, but its OK, I'm 90% sure that the hdpi devices get a compile error because of their screen densities.
Yeaaahhh. Its nowhere to be found lol. XD
On the latest build of CM9 when I hang up after a call it often times reboots. Just thought you should know :D
Still seeing reboots, usually when the CPU is under load.
Brought my clock speed down from 806 TO 700ish
What is CAI?
Can I go from aokp to cm9 with just wiping cache and davlik cache?
CAI is optimus s cm9 rom = Cold As Ice
And no its better to do a full wipe since they are very different roms
Sent from my LS670 using Android Central Forums
Thanks guys, I'll give them a go. Quick question though, how do you set your user agent to desktop? I've never had to do this so I haven't paid attention to it. And then the memory options? Another thing I've never had to do. I'll still give it a go and report back. Thanks a million.
Just a note... I'm making more progress on the ROM updater (I'm calling it a ROM keeper now). I made the dubious change to use a database to store the ROM list today, instead of reading a cached manifest file at startup. This is more "proper" but it turned out to be a lot of work. I also did a clean implementation of rdiff so I could make a nice progress bar for the patcher.
Anyway, I think it's shaping up nicely and I should have something to test in a couple days.
I'm getting these 'voice calling not supported' errors now. Not sure WTF is up with that, could have something to do with my LCD density but it hasn't been an issue until...well, today as far as I can tell. Going to have to go back to Gingerbread for the moment. Sadface x1000.
Status
GiftedWeeTodd
