ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
One of you guys mind taking a look at this logcat I just pulled for me? The phone reboots constantly with anything I do, not just quattrimus or ICS, and I can't pin it down. Sorry that I am not just attaching it. Don't have word on the computer im on
I/Adreno ( 3906): ioctl code 0x40140931 (IOCTL_KGSL_TIMESTAMP_EVENT) failed: errno 22 Invalid argument
W/Adreno200-EGLSUB( 4830): SetSwapInterval() interval: 0 not set
D/memalloc( 3906): /dev/pmem: Allocated buffer base:0x470f0000 size:614400 offset:1187840 fd:192
D/memalloc( 4830): /dev/pmem: Mapped buffer base:0x475f8000 size:1802240 offset:1187840 fd:61
I/ActivityManager( 3906): Displayed com.gau.go.launcherex/com.jiubang.ggheart.apps.desks.diy.GoLauncher: +4m54s628ms
D/memalloc( 3906): /dev/pmem: Freeing buffer base:0x475a0000 size:614400 offset:4915200 fd:266
I/ActivityManager( 3906): No longer want com.android.browser (pid 4770): hidden #16
D/memalloc( 3906): /dev/pmem: Freeing buffer base:0x47477000 size:614400 offset:3698688 fd:184
W/System.err( 4892): java.net.SocketException: socket failed: EACCES (Permission denied)
W/System.err( 4892): at libcore.io.IoBridge.socket(IoBridge.java:573)
W/System.err( 4892): at java.net.PlainSocketImpl.create(PlainSocketImpl.java:201)
W/System.err( 4892): at java.net.Socket.checkOpenAndCreate(Socket.java:663)
W/System.err( 4892): at java.net.Socket.connect(Socket.java:807)
W/System.err( 4892): at libcore.net.http.HttpConnection.<init>(HttpConnection.java:77)
W/System.err( 4892): at libcore.net.http.HttpConnection.<init>(HttpConnection.java:50)
W/System.err( 4892): at libcore.net.http.HttpConnection$Address.connect(HttpConnection.java:351)
W/System.err( 4892): at libcore.net.http.HttpConnectionPool.get(HttpConnectionPool.java:86)
W/System.err( 4892): at libcore.net.http.HttpConnection.connect(HttpConnection.java:128)
W/System.err( 4892): at libcore.net.http.HttpEngine.openSocketConnection(HttpEngine.java:308)
W/System.err( 4892): at libcore.net.http.HttpEngine.connect(HttpEngine.java:303)
W/System.err( 4892): at libcore.net.http.HttpEngine.sendSocketRequest(HttpEngine.java:282)
W/System.err( 4892): at libcore.net.http.HttpEngine.sendRequest(HttpEngine.java:232)
W/System.err( 4892): at libcore.net.http.HttpURLConnectionImpl.getResponse(HttpURLConnectionImpl.java:273)
W/System.err( 4892): at libcore.net.http.HttpURLConnectionImpl.getInputStream(HttpURLConnectionImpl.java:168)
W/System.err( 4892): at com.jb.gosms.goim.a.n.Code(GoSms:95)
W/System.err( 4892): at com.jb.gosms.goim.a.n.V(GoSms:266)
W/System.err( 4892): at com.jb.gosms.goim.a.n.I(GoSms:345)
W/System.err( 4892): at com.jb.gosms.goim.im.service.GOIMService$7$1.run(GoSms:2257)
W/System.err( 4892): at java.util.Timer$TimerImpl.run(Timer.java:284)
W/System.err( 4892): Caused by: libcore.io.ErrnoException: socket failed: EACCES (Permission denied)
W/System.err( 4892): at libcore.io.Posix.socket(Native Method)
W/System.err( 4892): at libcore.io.BlockGuardOs.socket(BlockGuardOs.java:181)
W/System.err( 4892): at libcore.io.IoBridge.socket(IoBridge.java:558)
W/System.err( 4892): ... 19 more
D/dalvikvm( 4892): GC_CONCURRENT freed 459K, 10% free 7205K/7943K, paused 3ms+4ms
Did you hit refresh?
That's what I had to do to get it to show up. Might give it a try tomorrow...don't really feel like redoing my entire phone tonight...or I might wait for the next release, had a lot of reboots on cm9 a10 final...
Sent from my LG-VM670 using Xparent Purple Tapatalk 2
That's what I had to do as well. But why doesn't it load the list initially? Do you not call the same method that the refresh option uses, in the onCreate() method?
This space intentionally left blank.
I downloaded AOSP and installed it then tried AOKP and it will not download. CM9 started but I did not want that and I did not see a way to cancel so I restarted my phone.
Reactions: tdm
Thanks. I'll look into a cancel button and better feedback.
Reactions: glarepate
I haven't gotten the redirect because I'm always on my phone. xD. But when I'm on my pc I'm using Linux. I hardly ever use windows on my pc. :D
Sent from my Cybertronian QuattrOV using Tapatalk 2000 (Now With Teleka-Typing!!!!)
I'm on windows and I didn't get redirected at all, just the warning from Google. I'm using a hosts file to blog ads and known viruses, so that might have saved me. I love hosts files.
Aosp, anyone know how to edit the power control widget?
@tdm: I don't know if you noticed at the time, but I resized the AOKP boot animation to MDPI. It's in this post:
bootanimation
Don't know if it's a concern of yours or not, but with the earlier builds, I had to watch the boot animation more regularly than I do now ;), and it got annoying seeing "eam kan" instead of "Team Kang". So feel free to include it in the next release if it make you happy.
Reactions: Badboytoast and tdm
bootanimation
Yeah I want to look into that more. I recall that the animation used to show fine in a8. I think it's the same file too.
So I remember there was a way around this but I can't remember The entire solution..... TiBu isn't restoring any Of my apps and I remember that the fix is by putting it in the /system folder but I can't remember where.....
No matter how many times I hit refresh, or how long I let it sit, RomKeeper never shows anyything
Which ROM are you using currently?
It didn't show anything on mine either, but I am using CAI, so I wasn't really expecting it to.
I'm running AOKP 10 and it's working fine for me. This is one of those obvious things, but just in case, are you positive you're connected to 3G or WiFi?
Or could it have been a corrupted download of the .apk?
Or, are you using an app that gives you granular control of app permissions, and that is preventing RomKeeper from connecting?
Can you get a logcat? Please filter the crap like ioctl messages if you're going to post it here. Thx!
Status
destypage12
