ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
I can enable it if it gives you warm fuzzies .. I just find it annoying. :p
Oh ha ha. I'm having second thoughts about being ready to put you down now:p In all seriousness though I hadn't had a way to test it since I got that new phone the other day, so I wasn't sure if something was disabled, or if I was still having the same problem. Good to go now.. and I agree that it is a little annoying and not needed.
downloadfing prwe3 via RK lets hope it works i have a flight to catch in an hour and audio rerouting needs to be going
I need some theme help. Some themes I try to apply say something about the theme was improperly complied, and I read something about you can apply the system theme then reboot and then apply the other theme then reboot, but when I apply the system theme reboot, then go back to the theme Chooser to apply the new theme I still get the same error. Any ideas?
You have to change your density to 140, apply the theme you want, change it back to 160, then reboot.(I use lcd density modder pro)
sent from my icy cold optimus using inverted T.T.2
beta1pre3 is up. Fetch via romkeeper, or I'll have the links in the OP shortly.
Changes since beta1pre2:
* Synced with CM as of today. thekraven says MMS broke in CM yesterday and it looks like they reverted that change, so it might be fixed now.
* Reverted to libaudio from alpha10. Please test audio routing (mic, speaker, etc.)
* Fixed camcorder. (thanks thekraven)
* Enabled bootlogo and chargerlogo. Booting with USB connected will go to chargerlogo.
Like the big blue Q. Nice to have the camcorder working.
Thanks!
Reactions: tdm
i downloaded b1p3 through rom keeper and once it was done i just hit install through rom keeper. it did this reboot thing and it installed fine. saw that camcorder was working and im real happy about that, the videos in the gallery wont play though. im about to wipe the system and do a fresh flash :) thank you tdm much appreciated :)
Reactions: Badboytoast and tdm
Oh tdm, I just want to say thank you for all the work you do, but the new boot logo makes me want to barf all over my phone. Just my opinion! ;)
It was just something I threw together. I'm terrible at graphics. Maybe this is motivation for someone to make something better. ;) It's a series of 8 (or I could use up to 12 or so) 320x480 images.
Reactions: kylemaguire
Thanks!
Interesting. BeWeather Pro vanished. Went to restore it, said it would replace an existing app. Told it OK, but it wouldn't install. Checked the apps, BeWeather is not listed. Not listed on widgets, either.
Hmmm, PlayStore doesn't work. I'll try flashing gapps...
Suggestions appreciated.
Edit: Gapps solved the problem.
Just fyi I've used RomKeeper to go from beta pre1 to nightlies to pre2 and now 3. I have been using the install feature and it reboots to my recovery (cwm green) wipes cache, dalvik and then installs the rom. Updating has been really painless. Thanks tdm for the great rom and update apk
Reactions: tdm
did anyone else get a blank white screen under the installed apps section of google play? everything was showing and it said installed apps but the list was blank. after going from p2 to p3 it started redownloading all my apps again and i couldnt stop it because nothing was showing under installed apps. any suggestions?
Reflash Gapps and it will reappear!
Reactions: cmerlyn
Status
Taylor Bag
