ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Tdm, what recovery do you recommend? I'm using Xionia and want to make sure I won't run into any problems. I haven't in the past, but I have heard of others having problems.
Edit: I need to reactivate my OV, can someone direct me to a stock rom for the old screen (2.2.1)?
Sent from my LG-VM701 using Android Central Forums
Get Cannibal by drewwalton, he did a version for the V.
LG-LS670 w thekraven CAI / ICS alpha 15d linaro2 & Tapatalk2
Reactions: Octahedron
The problem is that the .9.png's used to create the keyboard are too big and are crossing over each other creating that white line (sorta like when you hold up two semi transparent things and partially overlap them). It could be a problem with the aurora theme you are using, but I highly doubt it because I didn't theme swype and I doubt that swype draws from the framework images.
Try applying stock theme, rebooting, and then see how the keyboard looks without any themes. If it looks the same, I would assume that the keyboard isn't quite working for MDPI and that's the cause of your problem.
I am absolutely sure this is not a problem with the rom though.
Thanks Anthony, you seem to be theme Master general, but it still didn't work, thanks anyways though :)
G-T-R & Quattrimus CM9 Nuff' said.
(Also, sent from my LG-VM670 using Tapatalk 2.)
Thanks, but if I'm not mistaken this is a V thread not an S thread right?
Look at the original post, please. tdm is building for the S as well, teamed with thekraven. He has LS, VM and VS roms listed to download.
http://forums.androidcentral.com/op...acks/156426-rom-alpha-quattrimus-ics.html#anb
Code:
VM670
md5sum=86ed01b592b185cfa8b8cf3c557f4203
mirror1
mirror2
mirror3
LS670
md5sum=0bf58db1d39128545e6f6c3b81801b5f
mirror1
mirror2
mirror3
VS660
md5sum=3ec9caa511e815cc56b2dbc7dc186ed0
mirror1
mirror2
mirror3
Try leslieann's rhode utility ROM it's meant for activation and other stuff but not as a daily. :)
http://forums.androidcentral.com/showthread.php?p=1844277
Reactions: Revenant Ghost
Code:
VM670
mirror1
mirror2
mirror3
LS670
mirror1
mirror2
mirror3
VS660
mirror1
mirror2
mirror3
Hmmm, this has changed since last I looked. You are now proven to be better than me.
Reactions: jonny5449
Just picked up a cheap Bluetooth at Wal-Mart to try it out and calling works great. The rom is running smooth only one reboot from disconnecting the bluetooth headset. Running at 806/480. I've built allot of themes for cm7 but now this has everything I want so I think I'll start pumping out cm9 themes.
I had same issue & reboot running at 825/480
Reactions: Pkt_Lnt
And all ROMS are available via @tdm awesome RomKeeper, so he is hosting them on the server.
Not better, I was just blessed with an almost photographic memory and a passion to read, plus being a techno-weenie. ;)
I keep che hing back here every 5 min to see if the next beta is up what can I say I'm excited :P
Hey, so I branched cm9's android_external_wpa_supplicant_6 and made the changes to allow adhoc connections again. I havent built it yet because I'm at work still (it was a quick set of changes i actually edited through github browser.. yeesh). Needs to be built and tested :
https://github.com/Blackhive/android_external_wpa_supplicant_6
credits barnacle author:
szym.net ? Ad-hoc Wifi in Android
and this aosp modded wpa6 i found with most of the changes made already in the correct ics locations:
https://github.com/KFire-Android/wpa_supplicant_6/commit/57db145c0546b3c0350e652516929d444876265b
guess ill find out if it works if i can pry myself from my desk to go home >.>
Hi! First time posting, been using quattrimus since alpha9.
I'm running betapre3 and I.have.2 problems:
1: I can take videos with camcorder, but when I try to play them in gallery, it says video can're be played.
2: I can't get any tethering to work no matter what I try.
Help please!
Everything else works great, I love this ROM!
2: I can're get any tethering to work no matter what I try.
Help please!
This is why we read the first post :mad:
Help please!
Tethering/hotspot are not working properly atm check back in a couple of days :)
I cant get any apps to download through Google Play on my phone. The only way it works is if I reboot and they'll pop up when the phone restarts. Any advice?
Status
lluigidagg
