ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
@tdm
I know this is a bit off topic, but seeing you upgraded to the lg marquee does that mean your planning on porting this over?
I've been holding off upgrading since the OV has ICS and not the marquee (which is funny since its a newer, faster phone)
Just curious is all...I'm in process of switching to boost. Finally got my wives evo working this morning on boost, that was a challenge :D
Yes, it's been tremendously hard to continue working on the thunderc roms while my marquee is sitting by my side begging and pleading for some ics. As soon as I get aokp pushed out (hopefully today), I'm going to dig in to building for the marquee for a couple days, work on romkeeper updates, and then start prepping a beta announcement for quattrimus.
Did I mention I was busy? ;)
And you have a job other than making android. I started work this week and realized how hard it is to do anything for when you work eight hours and come home and want to go to sleep
So silly question that will probably get me shunned by the community(think Monty Python), but where is the "share screenshot" option? If it's not there, fine, but I feel like it was in the earlier alpha stages and now I can't seem to find it.
I notice I'm clearing my cache more often then I was used to because my phone starts to drag to a crawl, but after a cache clearing and a reboot it runs fine. Anyone else?
Sorry I'm not very familiar with LS670 basebands. Really all I know is that ZVH is gingerbread and all others are froyo.
So, since our kernel is based on the Sprint ZVH kernel drop, I would assume that ZVH would work best. Unless the RIL libraries are mismatched or something weird like that.
Which makes me curious why CAI is stated as being for ZVD... :confused:
Forgive the newbie question, but for the LS670 (Optimus S) what baseband should we be on prior to flashing this ROM, or does it matter? I ask because all other ICS projects I've seen for the LS670 want ZVD or ZVH baseband, and I'm on a rooted, Xionia-recovery'd ZVJ and would rather not have to downgrade again (had to go to ZVH to root) prior to installing this ROM if at all possible.
I didn't see a solid answer to this, but this is for ZVD not ZVH on the Optimus S. thekraven has always built for ZVD, some reason it is a lot more friendly than the other lol! CAI is ZVD as well.
So what about Optimus V users? I'm on ZV4....
To use Quattrimus on the LS670 you have to be on ZVD baseband. ZVH and ZVJ are newer updates, and are as TDM said Gingerbread, however if you flash this on either you will have a radio mismatch and will not be able to connect to data, or have phone service. Just the way it is for us Optimus S people.
Or I should say that is at least how it works with CAI....
Linaro is officially rejected from CM9 due to stability concerns.
I think I am just going to make an executive decision here and say that we aren't going with GCC 4.7.
AOSP master is moving to GCC 4.6, which is a step in the right direction and is much more stable. If we want to work with a new toolchain, this is a better choice.
Flashed this on my Optimus S and I've been getting problems with not having "proper root or busybox access." Flashed back to Kraven's CAI and everything is working fine again. The thing I like about Quattrimus though is the multitasking isnt the Sense multitasking. Is there any way to just get the stock android multitasking instead of Sense?
I have a question. Could the CPU deep sleep problem be causing me to receive my txt messages late? Because I notice as my device goes idle and the screen is off that even the clock stops and resumes after I wake my phone. Then I start receiving txt messaged people sent to me prior to me putting the phone to sleep. For example, If i turn off the screen at 1:00 then wake it at 1:05, the clock still says 1:00 then changes to the correct time after a few seconds. Then i receive my txts which were sent to me at 1:00, after i wake the phone. Any fixes?
This has been happening on all the previous releases too
I have the same problem with just the clock.
Status
kalikama1
