ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
I was going to get one made the other day but didn't get to it, was busy preparing for a job interview (which I just got actually), and now I'm traveling for about a week, but still want to give it a go. We still looking for about 12 frames max?
Sent from my LG-LS670 using Android Central Forums
Ya, 12 sounds about right. I know it was above 10 and less than 20, and no other value between those sounds right except for 12.
Reactions: acromack
Could someone point me in the right direction for installing cannibal over clockwork mod, much appreciated.
Cannibal open touch recovery: http://forums.androidcentral.com/showthread.php?p=1859176
Download the image
Rename it to recovery.img
Put in root of your sdcard
Open terminal and type:
su
flash_image recovery /sdcard/recovery.img
reboot recovery
Youll then be booted into cannibal open touch recovery ;)
G-T-R & Quattrimus CM9 Nuff' said.
(Also, sent from my LG-VM670 using Tapatalk 2.)
Now back to Quattrimus :) still running cm9, o have the stock settings, not a single reboot, :D pretty stoked about that part. As soon as I tried 806 max it started rebooting. But that was expected. No biggy. Smooth, fast and stable. Just that way I like it. Loving the amazing Work tdm. Huge thanks go out to tdm, thekraven, an everyone who made this possible. It is a shame about qualcomm's decision though :/ hopefully someone can make a wrapper to work things out :)
Yep market apps will not install on AOKP bp1. I was going to clear the data but it was not in the apps list.
Sent from my ARCHOS 80G9 using Tapatalk
just installed aokp market wouldnt work so i couldnt get titanium to restore any apps and with the alarm clock not working i had had to restore, cant wait for the fixes
Download the image
su
reboot recovery
Actually in the Op right next to the download there is .zip installer that you can flash in your existing recovery. Smooth like a baby's bottom...totally automated!
Reactions: inyourface09
I use flash image GUI to install recoveries on my M and V :)
Sometimes I have to rename it recovery.img for it to work though...
Is there a way to flash OI file manager or something to AOKP BetaPre1? Because The play store is not downloading anything.
i had the same issue when tdm first started issuing nightlies but it went away. it took two reboot to recoveries to finally reboot into recovery. Now no problem on beta 1 pre 3
What about the Amazon App Store? Anyone tried that out yet? I'm still running MiRaGe at the moment, otherwise I'd give it a try myself.
Try using data in general like your browser bc my data isnt working my 3g bars are grey not blue so although data is enabled its not working. Also i have never tried Aokp before and im in love :D
Also running AOKPbeta1pre1 at 245/864(max) it runs beautifly never had a rom run this smooth besides data not working :/
Sorry about the AOKP issues, I'm investigating.
Oh, and AOKP has stats now. Go to stats.aokp.co and select kangs. Currently 20 VM670 installs and 1 LS670 install (hi tlrsax54!)
omg....I'm famous....HOORAYY!!!!
AOKP: First off, it never showed up in RomKeeper. Downloaded from OP. Did my usual LeslieAnn Prep for New ROM and installed with no problems. Once it booted up, I have the same problem everyone else does, no downloads. Great WiFi reception, just no dl.
Actually, I was hoping that tdm's nifty built-in a2ext would kick in, but I guess that doesn't cross over from CM9.
I have great faith in tdm, and fully expect to get things working on this pretty soon. For now, back to CM9, which works wonderfully on my OV
Ok nvm reflashed data is now working......weird o.o. I find it funny im opening a ton of different apps just to see if i can get a tiny bit of lag out of it and i cant. Thankyou so much tdm :)
Status
koltyn
