ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
thekraven found the speakerphone fix from the p500 repo. Someone please test this to see if it works, and that it doesn't mess up any other audio stuff.
Thanks!
Okay I see what's going on. GingerKernel is apparently old and doesn't have PX_PROTO_PPTP defined, which throws all the rest of the macros off by one. The "real" ICS kernel has it and so does Linus' upstream (for two years now!)
So I'm looking at external/kernel-headers in the build tree and, of course, it has the ICS headers. It appears that your changes against this repo are applied on the gingerbread branch, so they don't apply to cm9.
So I'm guessing that all should be fixed now. Please verify with the latest nightly (love saying that!)
Thanks!
yes i made the changes to the gingerbread branch because I assumed we were using a gingerbread kernel and there would be less conflicts, unless your kernel has been mostly updated with ics updates then idk. ;p
We aren't using the gingerbread branch for the main build tree -- we can't, it would cause tremendous issues.
Did you test the nightly? Does it work? The speakerphone zip also has the changes, so you can grab that one if you like.
Hey TDM, when do you plan on having a Jelly Bean alpha ready? Shouldn't be long since they're announcing it today right? ;)
No one knows. The SDK is out but first CM will have to update and THEN /possibly/ tdm will make a build for the Optimus. The Optimus V's hardware ain't getting any newer.
cause screeches and echos on the other line for me
Thanks. Looks like I may need to separate out parts of that change (looks like there are several changes rolled up in one commit). And I probably need to align the kernel headers with the overlay headers, since the commit changed the overlay headers.
havent tested yet, will do shortly. I wasnt referring to the whole rom tree, I was just using the kernel-headers gingerbread tree, which if you say wouldve caused problems, was working for me lol. anyway corrected now in my build ^.^
I have a new error in log at with the softap error
06-27 15:24:08.460 W/Adreno200-EGLSUB( 2114): SetSwapInterval() interval: 0 not set
06-27 15:24:09.629 W/IInputConnectionWrapper( 3006): showStatusIcon on inactive InputConnection
06-27 15:24:09.629 W/InputManagerService( 1894): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@41107320 (uid=10050 pid=3006)
Status
ameliadinkins
