ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Re: [ROM][ALPHA] quattrimus CM9 (ICS)
Just installed it, works very smooth. Though I do have some issues, along with the ones already mentioned, like the wallpaper not scrolling and not receiving a 3G signal. It also seems to freeze in "Developer Options".
The wallpaper not scrolling is a bug in Trebuchet, not the ROM. You can use most other launchers and they will work perfectly, scrolling included. A lot of people like Launcher Pro, I like Balancer. YMMV.
When i tryed installing the chrome beta i got "unsuccessful" :o
I noticed the EQ in PowerAmp doesn't work. Player runs fine until you try to access the EQ, then it becomes non responsive.
Sent from the BACKside of Tapatalk
Has PowerAmp been upgraded to be compatible with ICS?
For all apps that have issues, please check the market info and/or developer's website to determine if the app has been listed as compatible with ICS.
Apps that do not state they are compatible with ICS may still be, and may not need any changes. But many will need changes. So if you don't see info anywhere indicating they are ICS compatible, please file a bug report with the developer of the app, not with the ROM devs here (we can't change apps). ;)
For people wondering about chrome beta not working, it is only supposed to work on armv7 devices, and it needs hardware acceleration to be enabled. We don't have either of those as far as I'm aware, so don't expect miracles.
Do you think this explains why navigation doesn't work?
No, I think the navigation issue has something to to with TTS, but I'm not certain atm. ;)
If you have a moment, run a logcat and post it to pastebin.com, then post the link here.
--Open terminal
--Type the following:
Code:
su
logcat > /sdcard/logcat.txt
--Press your home key to get out of terminal (not the back key, nor exit)
--Open Navigation and do what you normally do that causes a force close
--Re-open terminal (it should be in the status bar)
--Press the menu key to bring up the keyboard
--Hold the volume_down key and press the letter 'c' (this is cntrl+c)
--Open the logcat.txt file you just created on your sdcard
--Copy the contents to pastebin.com
--Post the pastebin url here
Thanks! ;)
--Open terminal
Code:
su
Thanks! ;)
file:///E:/logcat.txt
Here you are, I think. Hope this helps.
I think Im just gonna stick with the 2.3 on this phone. There is only so much this phone is capable of due to the processor speed ram available and the on board memory. Good luck!
heh no you need to upload the file to pastebin or edit out your personal info and use the code tags here.
@Jerry and other devs. There is a couple market apps that will autolog so people can run the phone and IIRC it will only start logging when its triggered by setting you input.
https://market.android.com/details?id=com.mgamerzproductions.logthis
https://market.android.com/details?id=org.jtb.alogcat
https://market.android.com/details?id=com.dromdev.test.logcat
Those what the devs in the SGS4G forums recommended recently.
It just makes getting logs eaiser.
PowerAmp 2.0.1 is compatible with ICS as long as the audio buffer is set to large. I've had minor problems with PowerAmp on BACKside, so it's not surprising that there are issues here. Not a huge problem or a dealbreaker for me.
I personally never had problems with playback with poweramp in ics. My problem is it will not play a song from individual folders, but always reverts to the whole library and will play from it.
Sent from your mom's phone.
I will admit i have not read through the entire thread, but has anyone noticed a Huge decrease in battery life with ics on this phone. The battery only seems to last me about 5 - 6 hours where as the 2.3 rom i run seems to last about 10+ mind you this is just with light use since I'm at work all day just the occasional txt here and there, and checking email on my breaks.
Yes i have definetly noticed thiis my battery used to last way longer with 2.3, now with ICS on ithe phone battery last about 6 hours :(
it is worth it, im juss tryin to fix anything i can and juss waiting for the next alpha maybe?
In sure it'll get better. IHO didn't always have the battery life it has now.
Status
No members online now.
BrüZZi
