ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Anyone else noticing that google maps (v6.9) FCs like a one legged stripper?
I'm running aokp a10
I love that movie xD. And last tone I was on aokp a10, yes I did.
G-T-R & Quattrimus CM9 Nuff' said.
(Also, sent from my LG-VM670 using Tapatalk 2.)
Reactions: droiddekka
still no hotspots with june 30 nightly, but thanks alot for the updates :P
Download and install barnacle wifi tether from the play store, 'check' skip wpa_supplicant, and do not set a WEP key(doesn't work when a WEP key is set).
sent from my un-dead sammich
Idk if anyone noticed this, but cm7 themes work with this. I did a dirty flash and had galaxy green cm7 running on harmonica and when my phone turned on after flashing cm9 the galaxy green them still worked! Lol :)
anyone flash the cm9 7-1-12 nightly for the ls670?
Sent from my LG-LS670 using Android Central Forums
Having Wi-Fi probs screenshot shows bar grey but its blue when it works and its grey any suggestions??
Rocking quattrimus and cna
I'm currently using CM9 beta1pre3 and while I was listening to music my phone froze and turned off. I turned it back on and it's been stuck on the CM9 boot animation forever. How can I fix this?
that normally means poor signal... ive experienced this myself on all our cm9 roms... i usually have 2-3 bars constant blue... (with gb)
Status
siratguidance56
