ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Re: [ROM][ALPHA] quattrimus CM9 (ICS)
Does gannon have the link posted somwhere else?
Beacuse i also want to extract the latinME but there is no link.
Actually dont he has a link in his blog site i just downloaded it
http://dl.dropbox.com/u/39195570/LatinIME.apk
there you go and the permissions will be this
i will remove both links if gannon requests to do so
Ok thanx bro
I didnt want to wait along time for the whole rom to download and then look for the apk...
doing it through my fone
theres the single apk and the permissions that is needed to be set
I use a different keyboard. I don't like the enter key on the bottom right, I prefer the Smiley key so i found a keyboard with just that. I don't remember the link but I'll just post it below instead.
curious why this doesn't seem to include terminal emulator or busybox.
Symbols keyboard works great for this, gives it a soft key feel. Fits the screen perfectly after u delete the Latin apk.some reason the Latin apk overturns it, it has theses symbols ツツ♥♡☆★♣☜☞ plus others ⓘ ⓛⓞⓥⓔ ⓘⓣ :p
Does any one know if flash will be supported in the Quattrimus ROM? I currently have Flash Player 11 running on my Lg Optimus V and I dont want to lose that compatibility. :)
How did you manage that when flash was designed for a different architecture then the ARM 6 that ships with the OV been trying to hack that in myself but haven't quite got it
There's a modified version of Flash Player 10 for ARM6 devices, found it on XDA.
Sent from my LG-VM701 Gelato 11-28 via Tapatalk
for anyone who likes to play with cm9alpha buy loves their daily... heres what i did to make popping back and forth easy for me... i have jerrys latest and greatest on one sd card, and tdms alpha on my other... that way i can play with ics whenever... and when im done, i just pop into recovery> wipe/format as normal> eject alpha sd> insert my green machine sd> restore my backup... and (cheesy grin) giggidy...
Reactions: Samuelg900
Flash player 11 is way much better than 10. I can give you guys the link if you guys want me to.
Apparently it's not really 11. It's 10 something, but it's always labeled 11. There's a way to check, but I forgot how.
Status
kankuraon
