ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Re: [ROM][ALPHA] quattrimus CM9 (ICS)
Ok, I thought that was a weird comment... Just had to ask though.
other then 3g being weird and my phone being warm very stable build.... how does leslies perform?
installed setcpu and found this just for everyones knowlage
This build is newer and solves some problems.
Also these phones don't support 120mhz, and even if it did, it's too low.
When any load exceeds your minimum, the cpu will spike to peak use until all use stops. Meaning you are either at 120 or 864. Since 120 doesn't work, that's bad.
When not in use it throttles down entirely, but any use will use up to your minimum. So playing mp3's yuo need more than 240, streaming audio, more than 240. 360 will work for those, but if you start using GPS, you will exceed 360 and and spike to peak again. This is why we recommend 360 for a minimum or 480 if you use gps, otherwise, your phone just bakes.
I have 1 question,what recovery should you use. I will give this a try. Great Thanks to all for this.
I say, if the recovery works for you, it doesn't matter. I use one of the first custom recoveries for the V because its Amon_RA based. :D
@ ajones23 CWM works just fine if you already have it installed
@cammykool You should atleast have it at 245, prolly 320 if you heavily using apps.
it was working fine at 120 but i changed the governer to smartassv2 min=245 max=729
For those with wifi problems, try setting your wifi to always stay on in the wifi advanced settings. Its not the perfect resolution, but it works
Reactions: OppyV
did you post that from taptalk? on ics?
That is fine if your phone is idle or at peak, nothing in between.
Streaming music, video and navigation will put you square in the center, meaning it will spike.
On Harmonia 2 I was able to run nice and smooth at 806 with no crashes or lag. I can only go to 748 on this rom. seems like it is smoother overall performance wise for an os liking it Great job to all the devs. I too cannot play you tube videos but i never did before so I don't care . Lets see how long the battery lasts .
im tryoing to get the est battery out of my phone seeing its not an OV kernel
Status
NVK
