ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Re: [ROM][ALPHA] quattrimus CM9 (ICS)
Lastnite I put CM9,on my sons OV. He likes it so far,have'nt had any problems so far. Its really smooth and fast,he really doesnt care that the camera doesnt work. I check in on this,I still have 2 OVs. Thanks tdm.
Reactions: tdm
I don't generally listen to music too often, but attempted to at work last night, (graveyard shift freight team at The Home Depot definitely needs a soundtrack!) Anyway, when using either Pandora or Tunein Radio, either app had issues freezing and after closing and reopening either app they failed to load properly without rebooting the phone. Pandora in particular cited a sync error of some sort when attempting to restart it after it froze. Never encountered this on any other roms. Music already downloaded on the phone plays just swimmingly btw ;)
Sent from my VM670 using Tapatalk
Thanks. I'll check out these apps over the weekend. Not sure if much can be done about it though.
Reactions: docliquid
Hi, has anyone looked onto the Bluetooth issue I raised back on page 143?
Sorry I haven't. I'll check out bluetooth this weekend or perhaps monday. But I hardly ever exercise call waiting, so odds of that getting much attention anytime soon are pretty slim.
Reactions: Germitty
I am having the issue of not being able to hold a phone conversation at all via bluetooth. cannot hear incoming audio and outgoing audio isnt audible either... Is this a issue that only i am experiencing ? I know it was a cm9 issue to begin with but your OP now reads that bluetooth is fixed.
Reactions: tdm
Tdm, you might want to add voice-to-text on the list of not working things. I haven't had any luck with it, and nor has a few other people. :)
Reactions: tdm
Thanks I'll check it out.
Reactions: chucksaysblah
thanks tdm i appreciate it! Greta work btw love this rom it is awesome if the bluetooth is fixed then i wont be looking at gb ever again.
I've heard that line (if "x" is fixed) from several different people for several different features. If you could all get together and agree on one feature to fix that would make my life so much easier. :p
(just kidding, by the way .. all the features need to work)
hahahaha I am sorry if i sounded demanding I wasn't trying to come across this way. I know you could care less if i use your rom or not and rightfully so. Thanks again for all the work you are doing if it wasnt for guys like you I would still have the crappy vm rom that came with this phone. I am actually using the rom anyways just would love the bluetooth functionality. I know it will be fully functional just as every other version of CM has been in the past. I will try to be less annoying lol.
EDIT: I also wanna note that i see two icons for the calendar in the app drawer now just in case you weren't aware!
Reactions: tdm
No problem, just trying to make a joke. I only expected a couple hardcore users to use this ROM for a daily driver until it hits beta release. But it sounds like there's a couple dozen at least. :eek:
Yes, thanks, the calendar issue was noted within an hour after release.
I've never noted myself as a "hardcore android user" but the only things to qualify a daily driver for me are ril (calling/texting) and 3g. And quite often smoothness :)
So im hardcore? Yay!
Does it make me more hardcore because I built from source for myself?
Hey guys, I'm not sure if I'm the only one with this problem. Sometimes my time does not seem to update properly, i mean right now it says it is 11:28 PM when i know it is 9:33 AM, is this something other people have experienced before? Usually i have noticed it happens on the lock screen. It will say the time from the last time i was on the phone until i wait a couple of seconds or hit the lock button and wake it again.
Reactions: tdm
Yeah it does that for me too.
I think the actual time is fine in the system, it's just that the UI is failing/forgetting to update it properly right after wakeup. But I'm not really sure exactly what' s going on -- all I know is that it always seems to resolve itself within a few seconds. ;)
Status
amateur_user
